Post by nuke on May 1, 2024 15:05:17 GMT -5
I was just working on a semi-hollow body guitar, 2001 Heritage H535 (which is killer by the way) which has some unique pickups, Heritage HRW's.
I had it apart to clean some powdery corrosion off the bodies of the pots. (the plating on Bournes pots seems to do that, just cosmetic in this case). I did take basic measurements of the pickups, was running out of time and fishing all the electronics in and out of 335 style guitars is a chore. So didn't do the plot. The data didn't seem to suggest anything peculiar about the pickups.
The instrument wiring has 500k volumes and 250k tone pots, with .022 capacitors. The particular manufacturer tends to do this, rather than the more common use of same value pots.
The other novel feature is the custom switch-tip, with the black dot. It is actually drilled and the black dot is inserted and cemented in place.
Only thing I might guess is Heritage bought the materials from Schaller, and wound them slightly over.
Also, Heritage only used these Bournes pots and values on HRW-equipped instruments, so pickups, harness and cool switch tip were a package deal. The pots appear to have a custom-taper, much smoother taper than most other volume/tone pots. Very usable taper and they have a good "feel".
The HRW pickups were a significant upcharge as well, back in the day. This particular H535 also has very figured maple, top, back and sides, wooden pickguard. So, a really nice one. I swapped the Schaller roller bridge and tail for standard Nashville and stop bar, since I'm more used to that.
Pics of the pickups, as you can see, they are made from Schaller components.
Heritage HRW pickups by Rendal Wall, Heritage H535 2001:
(built from Schaller base plates and components)
The pickup basic data (humbucker, covered, PAF style)
HRW Neck:
Screws North, 49-52 mt, alnico magnet slightly visible through a hole in the base plate.
Brass baseplate, chrome plated cover, 4-wire harness with Schaller color codes. Short legs, double mounting screws.
Neck position pole spacing, metric.
Ls 4.35 H @ 100hz
Q 1.95 @1khz
Cp 112.54 pf @ 100khz
Cs 113.12 pf @ 100khz
DCR 7.498k at 68-degrees F
HRW Bridge:
Screws North, 55-62 mt, alnico magnet slightly visible through a hole in the base plate.
Bridge position pole spacing, metric.
Ls 5.097 H @ 100hz
Q 2.08 @1khz
Cp 111.25 pf @100khz
Cs 112.44 pf @100khz
DCR 8.174k @ 68-degrees.
Just for comparison, I have a Schaller humbucker from about the same era, Neck position
Schaller neck humbucker (no cover from factory)
Screws North, 50-55 mt Alnico magnet visible.
Brass base plate, 4-wire harness, standard screws/slug configuration
Ls 3.98 H @ 100hz
Q 2.06 @1khz
Cp 96.19pf @ 100khz
Cs 96.44pf @ 100khz
DCR 7.477k @ 68-degrees F
Given the measured values, I'm not expecting a lot of difference shown in a plot, versus the standard Schallers. I don't want to try to open them up, due to the large solder seam and that they're in fantastic condition and the guitar sounds really good just as it is.
HRW Neck:
Ls 4.35 H @ 100hz
Q 1.95 @1khz
HRW Bridge:
Ls 5.097 H @ 100hz
Q 2.08 @1khz
Ls 3.98 H @ 100hz
Q 2.06 @1khz
Cp 96.19pf @ 100khz
Cs 96.44pf @ 100khz
