Post by ms on May 8, 2024 13:04:26 GMT -5
Here is part of a comment I made in guitarnuts2.proboards.com/thread/10690/humbucker-comb-filtering :
"...you should get close to a tele lead or strat sound without the hum by making humbuckers in this way:
1. Use fewer turns on each coil so that the inductance of two in series is what you want. Since inductance decreases faster than linearly with turns, you do not need to take off that many.
2. Use Alnico rod magnets for the right Q.
3. Do not use a tall Bobbin; the turns near the bottom do not contribute much to the level. So the turns you lose with respect to a strat pickup to get the right inductance cost you less level than you might think in terms of output if you are used to strat pickups with tall bobbins.
4. Lose the baseplate? Not sure; a nickel silver base plate kills some highs, but not that much. The cores are more important."
So a humbucker loses highs relative to a Fender type single coil as a result of the filtering effects of its electrical circuit (both higher inductance and higher losses, both largely from the permeability and conductivity of steel), and according to common belief, as a result of string filtering effects produced by the two spaced sampling regions. But it seems that the sampling issue really does not matter much, if at all. This is the result of the discussion referred to, and to some tests I did years ago.
So this discussion shows that you can make humbuckers with single coil properties.
First, why would you want to do this? A huge variety of guitars use original Gibson size humbuckers, but cannot be purchased with pickups that sound like Fender single coil, having both higher resonant frequency and lower loss (higher Q), and that reject magnetic hum. This discussion shows an easy pickup change that does all of this. Note that split coil with a normal humbucker only goes part way because of the steel cores, and loses hum cancelation.
There are a few humbuckers available that use Alnico rods. For example, here is part of a description of a humbucker made by Dream Songs Pickups (www.dreamsongspickups.com/en/content/strat-rod-magnets-humbucker)
"...It is a beautiful sounding humbucker with rod magnets and it also has the sound of a true Stratocaster single coil in split mode. This pickup works well with 250k pots, but you may want to try it with 500k pots fot a clearer and grittier sound in humbucking mode.
DCR from 10k to 12k
(I actually have some doubts about the claimed sound in split mode since this pickup is sold with a partial or complete metal cover, but I have never measured or heard one.)
This is not the kind of pickup discussed here. This discussion is about humbucker pickups that have a single coil sound when used as a humbucker, but they also can have a humbucker sound (with less output than a typical humbucker) by adding parallel capacitance and possibly resistance. That is, single coil sound does not require just a single coil, but can be achieved by designing for the proper electrical properties, and, almost as important, humbucker sound is retained by further modifying the electrical properties.
I have not found any such pickups for sale, but they are easy to make. Using Alnico rods results in less loss than steel, and less inductance, and so the required number of turns is similar to the minimum number used in available humbuckers. I have used two methods for making them:
1. Modify available humbucker bobbins, by drilling out the pole holes to fit available .195" Alnico rods, and wind with the required number of turns. (.187" rods might be easier to use; I have not tried these.)
2. Remove all the magnetic components and spacers from an available humbucker, modify the pole holes and install rods, using a custom made spacer so that standard rods can sit on top of the standard baseplate.
The first method offers more flexibility, and it is easy to drill out standard bobbins made from high quality strong plastic with a 5 mm drill (followed by hand clean up). For the second method, very inexpensive FLEOR pickups can be used, selecting the lower resistance two options (not the overwound ones). Things to watch out for:
1. Although the two coils in a pickup are well matched, the resistance can vary up to 1K from pickup to pickup.
2. DO NOT DRILL OUT WITH POWER. The bobbins are made from very soft plastic. Drill out by hand only, (if you must use power, use a special bit designed for soft plastic and be very slow and careful). A standard bit grabs, and you can destroy the coil and injure yourself.
It is not necessary to change the wiring at the pickup; in fact, it is not even necessary to disturb the tape around the two coils if you are careful.
Standard rods extend well below the bottom of the bobbin (both types of implementation, of course), and so you need to make a special spacer. I print mine, but cutting wood or plastic should work well also. Somebody might sell a shorter rod that would work with standard spacers.
So let's look at some measurements. These are impedance measurements, which are good at showing the location and width (losses or damping) of the peak and thus are good for comparing pickups and predicting the effects of a load. I display the magnitude of the impedance, which shows the peak, and the real and imaginary parts with the effect of pickup (and cable) capacitance removed. These days, I measure the capacitance with a meter at 100 KHz. This almost always gives a good enough value for the "unparalleling" computation.
The attached plot has six measurements. The three in the left hand column are standard pickups, and the three in the right column are humbuckers intended to sound like single coils. The one in the upper left is a Fender single coil type that I wound from a kit. The other two in the left column are Seymour Duncan humbuckers. The three in the right column have single coil properties, and they sound like them, too. They are not identical to typical strat pickups, but they work just fine in that role. I have not yet made measurements with an exciter coil. It seems that the output level is between a normal single coil and a humbucker, but it would be good to know for sure.
I have them in three guitars. Later posts will deal with wiring diagrams, etc., especially circuits to switch in typical humbucker sound. (In general, it is easier to lower a resonant frequency and increase damping, lower Q, than to go the other way, and so this is not so hard to do.)
DCR from 10k to 12k
