Hey guys, complete wiring noob here. Can someone please help with a wiring diagram for the following. I am almost done with a guitar build, and have the following:
3 x PAF Humbuckers, 4 wires each
3 x 500k Linear push/pull pods
1 x 3 way toggle switch (Gibson Style)
1 x 500k Linear pod
1 x 5 way blade type selector switch
So I want to do the following:
The standard pod needs to be for overall volume.
The 3 push/pull pods is one for each pickup.
Each pod must do its tone control, as well as coil split its allocated pickup.
The 3 way toggle switch must (if possible) give a bass boost in position 1, no effect in position 2 (centre), and trebble boost in position 3.
For the 5 way blade switch:
Position 1 - Bridge pickup only
Position 2 - Bridge and centre
Position 3 - Centre only
Position 4 - Centre and Neck
Position 5 - Neck pickup only
I have not ordered any capacitors ect, only the stuff on the list above, so I can order whatever I will still need.
Thanks guys
