Post by ssstonelover on Jun 22, 2024 17:21:04 GMT -5
This one has a bit of the Jazz Bass approach to wiring (for the volume pots) but the implementation for the 2 tone pots is a bit different compared to the single pot of the Jazz bass. The most interesting aspect is that the tone pots are not keyed to individual volume pots but affect the whole circuit, and than if both pots are turned down, then the treble cut is basically doubled. This turns out be be surprisingly useful as you can get either a moderate or deep treble cut AND there is a good amount of useful taper on both pots so there is quite a range on the treble cut. The cap both measure to 0.073uF ![](https://i.postimg.cc/ZYCj3Yjc/Rogue-Bass-LX200-B-RH.jpg)
