Post by doobiebrother on Jul 17, 2024 7:58:52 GMT -5
Hi all, I am working on installing an ilitch bpncs to my strat. My strat currently has two 500k pots (1 for vol, 1 for tone). Would everything function correctly if I just ignored that 2nd tone knob in the attached diagram from Ilitich? I've tried reaching out to them with no luck. I just want to make sure my bridge humbucker "sees" 500k and my single coils "see" 250k. Thanks in advance! ![](https://i.postimg.cc/bN1kvdYK/hex146E.png)
Post by newey on Jul 17, 2024 20:37:03 GMT -5
doobiebrother- Not following what you mean here. In the diagram you posted, the second tone control is marked "not used" and has nothing wired to it.
Post by unreg on Jul 17, 2024 20:44:46 GMT -5
Would everything function correctly if I just ignored that 2nd tone knob in the attached diagram from Ilitich Hmmm… according to the diagram, the second and also unused pot just has a ground wire soldered to its case. Nothing connected to its lugs. So, I say: yes, it will be fine to leave tone pot 2; don’t include it in your guitar. Only its case is currently grounded; why? I guess it can receive noise from you, but how would that noise affect the guitar’s signal? Its lugs are not connected. I just want to make sure my bridge humbucker "sees" 500k and my single coils "see" 250k. In my humbucker guitar, I replaced one of the pups with a DiMarzio Bluesbucker. That humbucker is really a single coil pickup with a dummy coil to kill the hum. With a 500K vol and 500K tone my guitar was extremely trebly. I replaced just the 500K tone pot with a 250K tone; it tons better now. However, I never use my real humbucker alone, by itself, so I’m not sure a 250K tone would sound great on only your humbucker; also my real humbucker came with my guitar so it’s not special; but, I do love my guitar’s sound now! 👍😀
Post by doobiebrother on Jul 19, 2024 12:07:48 GMT -5
So I have it all wired up and am so far very happy with the hum cancelling results. I do unfortunately find the single coils a bit bright and have liked the sound they had with 250k pots. I do have a 250k pot laying around and some resistors. Are there any changes I'd need to make to that diagram to make it like the Suhr style wiring (positions 2-5 see 250k and position 1 sees 500k)?
Post by doobiebrother on Jul 20, 2024 19:49:17 GMT -5
After doing some research on this question that has been asked a million times....
Would it work if I wired ~500k ohm resistance in parallel with the neck and middle pickups that should bring it down to 250k. If I wire those in at a4 and c4 (one end in the pin, other end to ground), would that do what I want (which is have the single coils see 250k and humbucker see 500k, all while having 1 vol 1 tone (both 500k pots))?
