Post by sumgai on Nov 4, 2024 0:20:54 GMT -5
frets , Err, your diagram above takes several turns away from Jack's circuit, which is shown here: The main thing I spotted was that essentially you are showing two volume pots in series, whereas Jack shows his pots in parallel, ala the standard guitar control setup. Neither of your pots will do much to alter the tone without also varying the volume in an undesirable manner. HTH sumgai
Post by reTrEaD on Nov 4, 2024 14:06:48 GMT -5
frets, I'm not quite sure what you're after with the treble-cut tone control. Were you intending '50s wiring and errantly misplaced the purple wire that would go from the wiper of the volume pot to the output jack? Or did you really mean have the output connected after the cap and have the tone pot as a shunt?
Post by frets on Nov 4, 2024 16:55:17 GMT -5
Guys,
I will redo the diagram. I took the other down so as not to confuse.
Post by reTrEaD on Nov 5, 2024 10:08:08 GMT -5
Guys, I will redo the diagram. I took the other down so as not to confuse. Since you deleted the entire post rather than editing it and removing the drawing, you won't be able to put your corrected drawing at the top of this thread. Feel free to start a new thread whenever you're ready, then I'll lock this thread and link to the new thread.
Post by frets on Nov 5, 2024 14:20:51 GMT -5
Thanks Retread, I appreciate it😺
