nuthugger
Post by nuthugger on Oct 2, 2006 23:06:14 GMT -5
Hi........I have a Strat, but the volume pot is too close to the bridge for my style of playing! I was wanting to remove the centre pot (tone pot) and move the volume pot into its place. Any assisstance would be greatly appreciated....Thank You
Post by UnklMickey on Oct 3, 2006 20:52:25 GMT -5
hi Nuthugger, welcome to GuitarNuts2. i guess your name refers to the fact that you like to play toward the headstock end of the fretboard. otherwise, i don't wanna know. (don't ask, don't tell...) re-locating your volume control shouldn't be hard. you will probably want to wire the remaining tone pot, so it is a master? you will have to do just a bit of soldering, but probably not so much. can you read a schematic? (this kind of drawing): or will you need a wiring diagram (pictorial)? like this:
snaar
Post by snaar on Oct 5, 2006 4:11:15 GMT -5
Hi Nuthugger
Welcome. i've got the same problem and just took out all the pots and replaced them with a circuit, very helpfully provided by unklmickey (see the thread - Removal of pots - in the wiring section). I also moved the selector switch right to the bottom. This does mean that you have to create your own scratchplate/pickguard (not something to try if you don't have the right tools/experience/knowledge - but after three or four botched attemps and loads of wasted plastic, it becomes easier). I have to say though that the guitar changed into a beast after that modification, and nothing gets in my way anymore.
robrhy
Post by robrhy on Oct 28, 2006 16:08:05 GMT -5
