jeremyo83
Post by jeremyo83 on Nov 1, 2006 10:43:04 GMT -5
Does anybody have any tips for refinishing a guitar with a satin finish?
I'm thinking about a natural wood grain stain, or maybe even a colored stain, but I've seen some stained guitars with natural looking satin finishes that don't look laquered.
Any suggestions on how to get this look?
Post by flateric on Nov 5, 2006 4:58:22 GMT -5
I use Rustins plastic coating for a really good hard seal to protect, then gently rub off the high gloss with a scotchbrite pad or fine wire wool. Thats all it is - a gloss finished thats been cut very finely on the surface to give a satin finish. You can do the same for any gloss coating, nitro, PU, PE, spray-can, paint, etc.
jeremyo83
Post by jeremyo83 on Nov 5, 2006 23:13:57 GMT -5
thanks, that seems to be what everyone is saying everywhere else too. i will have to give it a try.
Post by flateric on Nov 6, 2006 2:06:26 GMT -5
Danish oil for the back of the neck, 2 good wipes, then cure for a week and rub with a scotchbrite pad; it comes up beautifully silky.
jeremyo83
Post by jeremyo83 on Nov 6, 2006 13:06:18 GMT -5
*opens notebook.... scribble scribble.... raises hand*
what sort of place would carry this danish oil you speak of?
and just to be sure, can I apply this sort of treatment to a laquered neck?
Post by flateric on Nov 6, 2006 14:04:09 GMT -5
No need for danish oil if the neck is lacquered. If you don't like the hi-gloss or if it 'sticks' a bit just do the rub-down treatment onto your lacquer with 0000 wire wool or scotchbrite pad. Most hardware suppliers will carry Danish oil, it's even available over here in the uk, in B&Q and Homebase.
