Post by mr_sooty on Nov 19, 2006 23:52:49 GMT -5
Can any Strat neck go on any strat? For example, if you have a vintage reissue (as I do), can you chuck a 22 fret Am standard neck or something on it as a straight swap?
Post by flateric on Nov 20, 2006 2:54:29 GMT -5
As far as I know, Fender Strat necks over the past decade have shared the exact same heel shape and dimensions. But every pocket will be a tiny bit different, you may need to do a little shimming or filing but basically it will work.
Post by mr_sooty on Nov 20, 2006 16:23:28 GMT -5
Cool, cheers.
Post by morecowbell on Dec 5, 2006 18:32:53 GMT -5
For what it's worth, I've put a Fender '57 reissue neck on a MIM Strat with no problem (did have to shim it in the back of the pocket with a piece of matchbook cover-weight paper, though, but then you might have to do that with any neck). I've done the same with a Mighty Mite replacement strat neck, also with great results. Good luck with your mod.
