bigaldo
Post by bigaldo on Apr 24, 2007 17:48:08 GMT -5
Is there any help online about,installing,pulling,repairing guitar body studs?I have one that isn't 90 deg. off body,and isn't flush with body.It seems to be about 1/32" out from being flush,Any ideas or help?
Post by dd842 on Apr 24, 2007 21:58:07 GMT -5
Is there any help online about,installing,pulling,repairing guitar body studs?I have one that isn't 90 deg. off body,and isn't flush with body.It seems to be about 1/32" out from being flush,Any ideas or help? Hi bigaldo, What about glueing a piece of hardwood (dowel maybe?) into the hole and then carefully boring out the new/desired hole? Dan
bigaldo
Post by bigaldo on Apr 26, 2007 0:56:59 GMT -5
Yes,I could do that,but I feel its not justified for this problem.I think I will just try to reseat the 1 stud.If it doesn't work then I'll go with your idea.
Post by dd842 on Apr 26, 2007 8:06:54 GMT -5
I think I will just try to reseat the 1 stud.If it doesn't work then I'll go with your idea. Sounds good to me, bigaldo. ... and thank you for using the word "idea" (not suggestion), as it is just an idea. All the best, Dan
bigaldo
Post by bigaldo on May 2, 2007 14:48:26 GMT -5
One little tap with a soft faced hammer took care of it.
Post by dd842 on May 2, 2007 15:00:29 GMT -5
One little tap with a soft faced hammer took care of it. I didn't know you wanted to get into such exotic methods ;D Dan
