jamie
Post by jamie on Jul 30, 2007 2:36:21 GMT -5
My Les Paul guitar goes out of tune after playing for a few minutes. Its seems to happen more after bending strings(before you ask, yes the strings have been stretched in). I think the strings are getting caught up in the nut. I read somewhere that they used to oil the nut. My other good guitars have roller nuts and locking nuts, so ive never had this prob before. Anyone else had this problem?
blueswaite
Post by blueswaite on Jul 30, 2007 14:29:45 GMT -5
You can put pencil lead because it is graphite in the slot and see if that helps. I know guys who have done that for a temporary fix to find out if that was the problem. Good Luck
Post by gfxbss on Jul 30, 2007 17:15:40 GMT -5
i am also familiar w/ the pencil method. are you sure that the tuners are good? do your nut slots need filed? youre not having any problems w/ the strings slipping out of the saddles are you?
Tyler
Post by gfxbss on Jul 30, 2007 17:19:31 GMT -5
p.s. what material is the nut made from?
Tyler
jamie
Post by jamie on Jul 30, 2007 23:39:07 GMT -5
>> are you sure that the tuners are good? The tuners are not of great quality. I didnt suspect the tuners at first as i just assumed that they would be stable.
>> do your nut slots need filed? thats what i thought because the strings sit tightly in the nut. but after a closer look there should be enough room for the strings to slide through.
>> youre not having any problems w/ the strings slipping out of the saddles are you? the strings sit in the saddle slots quite well. The whole bridge area seems pretty solid and stable.
>> what material is the nut made from? The nut material is nylon. Its very hard but probably doesnt have the slip factor of bone or graphite.
first thing to do is to put some lead on the nut. I also noticed that i didnt put enough wraps on the tuner posts(im used to locking tuners). Maybe this is the major cause(almost certainly). I will eventually replace the tuners with grovers or something. That should see it playing in tune.
Post by gfxbss on Jul 31, 2007 5:25:33 GMT -5
i was just asking as i have had this problem w/ les paul copies and the tuners were a bit loose.....
if you would like, you could still file the nut just to be safe.... and youre correct, nylon does not have the slip factor of bone or graphite.
the not putting enough wraps around the peg could definitely have something to do with it. the guitarist i work on during my current project never puts his strings on properly and has this exact problem....
Tyler
jamie
Post by jamie on Aug 1, 2007 7:36:53 GMT -5
>>> not putting enough wraps around the peg <<< I cant believe i made such a silly mistake. This is something people learn when beginning to play guitar. Its so easy to forget the simple things.
Post by gfxbss on Aug 1, 2007 15:57:39 GMT -5
so ill take it as that was the problem?
it is true, the early things are the easiest to forget
Tyler
Post by sumgai on Aug 1, 2007 16:09:31 GMT -5
it is true, the early things are the easiest to forget That's not quite true, young man. I can still remember the phone number of the first house I grew up in, starting from the time I was about 4 years old. But I'll hanged if I can recall what the hell the topic is we're talking about here..... can ya help a brother out? ;D sumgai
Post by gfxbss on Aug 1, 2007 21:58:44 GMT -5
haha, the only reason i can remember my first phone number is cause i still live in the same house. i cant even remember if i ate breakfast this morning, let alone what.....
Tyler
Post by sumgai on Aug 2, 2007 15:14:58 GMT -5
Tyler, Well, that's what you get when your diet consists of sex, drugs and rock n' roll! ;D At least, that was my problem, I don't know what yours is. sumgai
Post by gfxbss on Aug 2, 2007 16:54:37 GMT -5
thats the thing, i dont remember
Post by sumgai on Aug 2, 2007 20:18:42 GMT -5
Tyler,
OK, you win! ;D
coo1nt
Post by coo1nt on Aug 3, 2007 2:12:14 GMT -5
>>> not putting enough wraps around the peg <<< for me i find that using the least amount of string, 1 or 2 wraps keeps me in tune, when i started playing i wrapped the string alot and it kept going out of tune
Post by UnklMickey on Aug 4, 2007 10:33:37 GMT -5
...I can still remember the phone number of the first house I grew up in, starting from the time I was about 4 years old... But way back then, phone numbers were only 3 digits long. How hard could it be to remember?
Post by sumgai on Aug 4, 2007 13:00:39 GMT -5
But way back then, phone numbers were only 3 digits long. How hard could it be to remember? You adults! You're always spoiling my fun! ;D sumgai
