blueswaite
Post by blueswaite on Jan 20, 2008 19:12:35 GMT -5
In my old age it is alittle harder to chord. I have 9s on my strat and it plays easy but I love 10s. I tuned down a 1/2 step and it is really easy to play. Being tuned down if I put 10s on is it going to help make the sound not quite as brite. What are the advantages. I should probably put a set of 10s on to see. I need to decide before I take it into to have a set up done on it. Thanks
Post by dunkelfalke on Jan 21, 2008 6:54:43 GMT -5
what exactly is the problem just put some .10 strings on your strat and try it out. if you like the sound, make a full setup after that (neck, intonation, springs). you don't have to do a full setup just for trying out a different string size, especially in your case (tuned down).
blueswaite
Post by blueswaite on Jan 23, 2008 21:52:13 GMT -5
Put 10s on went back to nines. Will have a set up done with 9s. On my Ibanez with the 24 3/4 inch scale I can use 10s but the Strat I'll have to stick with 9s.
newswede
Post by newswede on May 19, 2008 4:35:29 GMT -5
Just a note for you, GHS makes 9.5 sets. Very balanced. They could do the trick for you!
newswede
Post by newswede on May 19, 2008 4:38:25 GMT -5
I found the model # on ghsstrings.com. Here are the gauges:
9.5 11.5 16 24 32 44
