Post by phalangestyle on Jun 8, 2006 20:21:58 GMT -5
Just like the old story goes, I found an older MIM Strat in the attic of a house i was working on... struck a deal with the owner and brought it home. I've never seen one set up like this: The enclosed pictures show a switch where the lowest tone knob goes and a dual pickup in the bridge position... The pickguard was not hacked at all suggesting it came from Fender this way. I'm not well versed in your world GuitarNuts, what have I found here?
Post by UnklMickey on Jun 8, 2006 20:53:07 GMT -5
hi phalangestyle, Welcome to Guitarnuts2. i think you were trying to do this: i sent you a personal message so you'll know how to do it yourself next time. unk
Post by dunkelfalke on Jun 9, 2006 4:21:29 GMT -5
a fat strat with a splittable humbucker?
Post by Runewalker on Jun 9, 2006 8:50:31 GMT -5
Not so much an oddball, just a fat strat with a coil splitter as suggested by DF.
Of note however are the Singles with a P-90 dual magnet design, and of course the humbucker. A clear indication of Gibson envy by Fender.
Post by dunkelfalke on Jun 9, 2006 12:44:59 GMT -5
to be honest i never have seen other singlecoil designs. always dual magnets.
Post by phalangestyle on Jun 9, 2006 18:19:07 GMT -5
hi phalangestyle, Welcome to Guitarnuts2. i think you were trying to do this: i sent you a personal message so you'll know how to do it yourself next time. unk Thanks for the assist... My original post is coded for clicking the thumbnails for a larger image, I could've pointed that out in the post though.
Post by phalangestyle on Jun 9, 2006 18:21:57 GMT -5
Not so much an oddball, just a fat strat with a coil splitter as suggested by DF. Of note however are the Singles with a P-90 dual magnet design, and of course the humbucker. A clear indication of Gibson envy by Fender. Thanks DF and Runewalker for the info... Where can I read about playing techniques using this setup and where might I get replacement pots and knobs? I'm thinking since it was built like this it is desirable to keep it stock other than the usual shielding etc.
Post by UnklMickey on Jun 9, 2006 18:27:22 GMT -5
... My original post is coded for clicking the thumbnails for a larger image... doh!looks like i'm the one that's learning something new! thanks BTW, ChrisK seems to have a wealth of knowledge when it comes to all things Fender. send him a PM and ask him to ring in on this one. unk
Post by dunkelfalke on Jun 10, 2006 2:32:04 GMT -5
Thanks DF and Runewalker for the info... Where can I read about playing techniques using this setup and where might I get replacement pots and knobs? I'm thinking since it was built like this it is desirable to keep it stock other than the usual shielding etc. everywhere where you can find guitar parts. for example store.guitarfetish.com/as for playing, if you want a humbucker that sounds not so hot but rather bright, just split the coil with the switch.
Post by phalangestyle on Jun 11, 2006 10:15:12 GMT -5
Thanks for the link DF... They had just what I'm looking for store.guitarfetish.com/hueqhssprasp.html Any pitfalls to using this admittedly cheap prewired pickguard till I can find a replacement dual pot that is broken on mine?
Post by dunkelfalke on Jun 11, 2006 13:18:35 GMT -5
Post by UnklMickey on Jun 12, 2006 9:20:00 GMT -5
....Any pitfalls to using this admittedly cheap prewired pickguard till I can find a replacement dual pot that is broken on mine? yeah, you might find that you like it better than the original. then, what do you do? unk
Post by phalangestyle on Jun 16, 2006 14:57:16 GMT -5
....Any pitfalls to using this admittedly cheap prewired pickguard till I can find a replacement dual pot that is broken on mine? yeah, you might find that you like it better than the original. then, what do you do? unk :-) Now that would be a stroke of luck! Thanks for the dose of reality... My "other" hobby is customizing cars, you would not believe the long list of things you can't do in the name of "authenticity"!
Post by christopherhopkins on Aug 5, 2006 18:53:14 GMT -5
It's the scratchplate for a Strat Special which was known in the UK as the Contemporary Strat.
It's definately not a hacked plate - that's how they came out of the factory. HSS with Master Volume, Master Tone (a TBX!) and a coil tap switch.
I've got 2 - my original one which I bought in 1996 has a fantastic neck and a heavy body. I bought one of EBay that has a wonderful light body but a not so hot neck. So I've made a hybrid. It's currently sporting a white plate with single coils (hotrails at bridge and 2 gold lace sensors) and the standard Volume, twin tones. (Neck and Bridge - no middle).
The other one has been fitted with Lace Sensors too (Dually Red at bridge, gold at middle and silver at neck). It's going to be modded to go back to Master Volume and Master TBX Tone...The 3rd hole is going to have a 4P3T switch to put the Dually Red into Single, Series or Parallel Mode.
Post by vonFrenchie on Aug 8, 2006 19:26:26 GMT -5
phalangestyle.... screw authenticity, put direct injected engine in a 69 Charger. Paint it teel with an American flag on top and call it the General McClellan.
