dasbeef
Post by dasbeef on Jun 24, 2006 9:01:24 GMT -5
I'm looking to get a Telecaster bridge that will take a full size humbucker, but only has 3 mounting screws. I want to be able to fit it directly onto my mexican Tele, without having to drill new holes or anything. Can anyone tell me where to aquire such an item?
Post by UnklMickey on Jun 27, 2006 13:25:42 GMT -5
hey Keith, i see this one hasn't gotten any responses for a couple days. i don't know much about the variations in Tele bridges. when you say only 3 mounting screws, are you talking about the 3 between the saddles and the tail of the assembly? like this one: us.st11.yimg.com/us.st.yimg.com/I/yhst-50206111187217_1899_4309926or did you mean something else? unk
dasbeef
Post by dasbeef on Jun 28, 2006 12:06:15 GMT -5
Hi, cheers for the response. I shall hopefully demonstrate graphically. Here is a pic of the bridge that is currently on my guitar. You'll see two mounting screws at each side, and one in the middle, just under the saddles. I tried this hardtail bridge. I'm not sure of my options here. The center screw is common, but the two outside screws are in a slightly different place. I think this would be an easy bridge to fit as id use the common center screw, and then I'd just need to square up the bridge. I am unsure of the options I then have for fitting the humbucker at the bridge. Here's a pic... I'm not sure if I could use a pickup surround, or if I'd need to extend the scratch plate. I really am unsure of this and need help. I maybe should have posted this in with the rest of my project, but I figured that someone would have a quick answer, and it's got nothing to do with wiring. Any advice would be greatly appreciated....
Post by UnklMickey on Jun 28, 2006 15:39:21 GMT -5
hi Keith, pictures do speak a thousand words. i looked at the pictures of the tele bridges for HBs on the GFS site: store.guitarfetish.com/chhubrforteg.htmlit looks like the ones that have 3 holes, have a different spacing. i still think that a HB / bridge plate will work best here. if the screw spacing is identical, that would be easy. but i suspect you won't be lucky enough to for it to be that easy. if the holes are close, but not exact, that's the worst case. if they are very different, you can drill new holes in the guitar OR, drill additional holes in the new bridge, that line up with the existing holes in the guitar. as far as getting a bridge with the exact spacing as your existing one, ChrisK might have some suggestions on where to start your search. he seems to know the right folks at Fender. i might guess if you got in touch with the right person there, with model and serial # of your guitar, maybe they will have a source for a drop in replacement. i don't think Fender has any models with a HB at the bridge, that mounts on the bridge plate. i'm fairly certain they mount their bridge HBs directly to the (larger) pickguard. in any case, maybe Chris or someone else, more tele-knowledgeable might be able to help. unk
Post by ux4484 on Jun 28, 2006 17:37:32 GMT -5
i don't think Fender has any models with a HB at the bridge, that mounts on the bridge plate. i'm fairly certain they mount their bridge HBs directly to the (larger) pickguard. unk When I saw this post, I seemed to recall spotting a Tele with a HB in the bridge last time I was at GC. It looks almost exactly like the one unk posted. Here 'tisThe models at guitarfetish, are the same bridges sold by Southeast music and reliable fender on ebay (I'm almost positive). If for no other reason, go to one of their ebay stores, as they have a technical drawing of the bridges they sell, so you can get an exact measurement.
Post by ChrisK on Jun 28, 2006 18:55:48 GMT -5
I'm not really aware of any three-hole /tele humbucker bridges.
The info on the John5 Tele does not indicate whether it is a three-hole or four-hole screw mount. Go to Guitar Center and find out!
(This IS a homework assignment!)
OOPS, sorry, I just realized that you're on a different planet from Guitar Center. I'll go and check this weekend.
I've used the Gotoh (methinks) from Warmoth and the Twangbucker from Rio Grande, but these are four-hole.
In ANY case, even if you find a bridge that fits, you'll need to route the body for the larger pickup.
One just might want to consider the single coil sized four-wire humbuckers available for a Tele from many sources.
Now, that John5 slot-less control plate IS interesting, eh!
dasbeef
Post by dasbeef on Jun 29, 2006 16:50:31 GMT -5
Yes!!! The slotless control plate is interesting. I am after one. I tried e-mailing Fender UK a couple of weeks back concerning spares for the J5 tele (bridge and control plate), but they said there were none available. I shall have to try Fender US and maybe try the US eBay as well. So far all the UK sites, official and otherwise, have not provided any solution. All your help is greatly appreciated. Thanks very, very much guys!!!!
Post by UnklMickey on Jun 29, 2006 17:00:24 GMT -5
being a blade fan, i think the LP toggle on the upper bout is sort of limiting.
for many of us, the lack of a slot on the control plate, is just un-realized, real-estate.
but for guys who have a drawer full of rotary switches...
Post by vonFrenchie on Jul 2, 2006 15:04:35 GMT -5
This bridge looks like it would fit. Im judging based on the two outer screw holes. www.stewmac.com/shop/Bridges_tailpieces/Electric_guitar_non-trem_bridges/1/Modern_Tele_Bridge_for_Humbucking_Pickup/Pictures.htmlSorry the link is too long. In my opinion I'd go with the GuitarFetish bridge. Putting a few small holes in your guitar is worth it if your saving 35 bucks. This is what it looks like and you can compare for yourself. Unk.... you dont realize that some of us have guitars that dont have pickguards or have guitars with metal pickguards. Yes, it's hard to make a thin slot in a metal pickguard... Ive tried. Chris... the Twangbucker is one of the greatest pickups ever. It just looks so cool.
Post by ux4484 on Jul 11, 2006 11:44:30 GMT -5
I was on ebay today, cruising Souteast music's store, they have a BT4 Tele bridge that clearly has three rear mounting screws. The picture that shows the mounting is for the gold model "GOLD Telecaster HUMBUCKER BRIDGE for Fender Guitar BT4" but they have the same model in chrome. Here's the pic:
Post by ChrisK on Jul 11, 2006 20:03:52 GMT -5
dasbeef
Post by dasbeef on Jul 14, 2006 21:32:01 GMT -5
I'm not winning with this at all. Fender USA gave me a pretty crappy response saying they don't make 3 mount humbucker bridges, and to try stewmac, or some other place I'd already tried. Never even mentioned the J5 plate which I did also ask about. The email response was 1 sentence!!!! Shall have too rethink. Some of the bridges suggested look pretty good, so thanks for that!!!
Post by ChrisK on Jul 17, 2006 16:29:45 GMT -5
Best of luck!
Post by ux4484 on Jul 27, 2006 10:49:21 GMT -5
dasbeef,
After replacing the bridge and tuners on my '79 Cortez Tele copy, I've started playing it a bit more, which has made me recall how lackluster the pickups are. I thought about this thread, and decided to stop by GuitarFetish. I really don't want to replace the bridge again, so I opted for the "modern vintage" mini humbucker drop-in replacement pups and a push pull pot to split the bridge pup coil. I noticed they also have a drop in "hot lead" mini HB available.
Would you consider one of those....a lot less work...and no routing required.
have you taken the project any further?
