bavonda
Post by bavonda on Oct 3, 2007 12:26:27 GMT -5
I am interested in replacing the Neck single coil in my MIM Fat Strat with a Hot Rails. The wiring schematic from SD is different from the wiring of the stock Fender humbucker present in the bridge position. Can you explain to me why (is the color coding of manufacturer different??) More importantly, should I wire the Hot Rails according to SD or should I wire similarly to the Fender Humbucker already in the guitar bridge position?
Post by sumgai on Oct 3, 2007 12:47:21 GMT -5
bavonda, Hi, and welcome to the NutzHouse! ;D In case you don't yet know it, there are no industry guidelines for what color wire to use on pickups, so there is a great variety out there. For that reason, it's almost always best to use the diagram produced by the pickup's manufacturer, at least in the beginning. Unless warned by others that there's a mistake on that company's drawing (fortunately there are very few of them), you should be able to make things work with the least amount of hassle by following that design. After that, if things don't sound the way you want, then you can experiment. ;D HTH sumgai
clr
Post by clr on Jan 17, 2008 18:00:04 GMT -5
I have the hotrails in the bridge position, and it's awesome on distortion, but really goes down the drain on clean. Sounds like the tone knob is rolled to 0. Thats just in my opinion...onward
What way did you want to wire the pups?
Post by ChrisK on Jan 17, 2008 19:07:43 GMT -5
clr
Post by clr on Jan 21, 2008 21:28:06 GMT -5
Keep in mind, that there are 5 wires, 1 of them being bare which is connected to ground with green.
