clr
Bzzz!
Mar 7, 2008 23:23:56 GMT -5
Post by clr on Mar 7, 2008 23:23:56 GMT -5
So I've finally decided to get around to setting up my Les Paul copy to my specs. The relief was just fine as is, but lowering the action (I use a dime to gauge the string height) gave the higher strings (on the ninth and twelfth fret) a slight hint of buzz. Bending the ninth and twelfth completely muted the strings. I tried raising the action back up, and sure enough it took away the muting, but it was higher than my low E I think it's a fret problem. Anyone?
Bzzz!
Mar 8, 2008 14:09:02 GMT -5
Post by sumgai on Mar 8, 2008 14:09:02 GMT -5
clr, Yes, you have a couple of problem children. Look closely at the suspects. If they're raised up out of the fingerboard a very small amount, you can probably get away with tapping them back down. Use a very light hammer, preferably a 'dead-blow' type (the head is nylon, leather, rubber, or something similar that doesn't bounce (it has no inertia)). If the fret is down flush like it should be, then the one behind it is worn. If that one isn't too bad (no grooves), then you can probably get away with a light fret dressing. Just be aware that to do the job correctly requires a file that runs as much as 40 Somalians. Yikes! Said file can be found here: www.stewmac.com/shopby/item/4491(Hey, a Stew-Mac link that's clear and cogent...... imagine that.) If things are way out of hand, or your comfort level has been exceeded by this conversation, then you should consult with your local guitar guru. HTH sumgai
clr
Bzzz!
Mar 8, 2008 18:50:36 GMT -5
Post by clr on Mar 8, 2008 18:50:36 GMT -5
file that runs as much as 40 Somalians. Yikes! Hahaha! Hey I actually got that! But it's covered under its warranty.
Bzzz!
Mar 9, 2008 23:59:25 GMT -5
Post by sumgai on Mar 9, 2008 23:59:25 GMT -5
clr, Real Guitar Nutz don't hide behind no warranty! ;D Cool that they'll honor the warranty, even after you "set it up to your specs" (to paraphrase your statement). And if you remember/know what a Somalian is, you're older than you look! ;D sumgai
clr
Bzzz!
Mar 13, 2008 19:15:41 GMT -5
Post by clr on Mar 13, 2008 19:15:41 GMT -5
And if you remember/know what a Somalian is, you're older than you look! ;D I live in Toronto. And Orlando Bloom was a poor excuse for an elf going down ropes.
