netejua
Post by netejua on Oct 20, 2005 8:46:40 GMT -5
first of all this is my first post here ;D. so i use a line 6 spider 112and its fine but i want a real clean channel not an effect that sounds like a clean channel and i been trying amps left and right and the ones that i like are really expensive and the amps in my budget are modeling amps. so can anyone tell me a good amp below 600 usd? i play mostly rock and blues (some times a little bit of metal) and i use a ax1500g. thanks
bty sorry about my writting
Post by dunkelfalke on Oct 20, 2005 12:37:48 GMT -5
Post by Trey on Oct 20, 2005 17:58:52 GMT -5
Carvin Vintage Series amps, Fender Blues Deluxe or Hot Rod Deluxe(used), Roland Jazz Chorus. All of those have pristine clean channels...
netejua
Post by netejua on Oct 21, 2005 8:07:53 GMT -5
what kind of amp is that dunkelfalke???
Post by dunkelfalke on Oct 21, 2005 11:08:03 GMT -5
madamp - a small and extremely inexpencive two channel 15 watt tube amp kit. if you already have a cabinet and know someone who can solder than it would be perfect. the assembly instruction is very good and detailed.
Post by vaisatsteen on Jan 8, 2006 22:21:54 GMT -5
