Post by fenderstrats on Jan 18, 2006 18:29:48 GMT -5
Anyone have an Idea where I can find some info on this Amp. It has a rotary type function motor that when turned on makes the speaker sound like a Lesley. There is a small can type enclosure that gets filled up with some type of oil lubricant (now dried up ) and Im trying to find a sutiable replacement for the oil or whatever it uses. Any help is appreciated thanks...
Post by UnklMickey on Jan 18, 2006 18:55:47 GMT -5
Post by fenderstrats on Jan 18, 2006 19:43:34 GMT -5
Thanks for the info UNK. Invisibility ?
Post by UnklMickey on Jan 18, 2006 20:20:18 GMT -5
next time you're logged on scroll down to the bottom of the screen.
you'll see the names of all the users that are logged on at that time.
but you won't see yours. instead you'll see "1 invisible user"
you have invisibility set in your user profile.
Post by fenderstrats on Jan 24, 2006 14:45:55 GMT -5
OK have changed it to vis.
Post by UnklMickey on Jan 24, 2006 14:58:31 GMT -5
were you able to figure out what kind of oil it was?
transformer dielectric? silicone oil?
