koko276
ohms
May 8, 2007 5:55:00 GMT -5
Post by koko276 on May 8, 2007 5:55:00 GMT -5
any one know about this ohm thing? if I have an 8 ohm amp does the cabinet have to be 8 ohms as well? I also have a cabinet rated at 16 ohms and I'm running my big amp through it and it is switchable between 4,8, and 16 amps. Any input would be appreciated on how to understand the matching.
ohms
May 8, 2007 7:33:32 GMT -5
Post by DarKnight on May 8, 2007 7:33:32 GMT -5
I hope these help. ;D What impedance ("ohms") is and what it meansCalculating impedance valuesSo basicly your amp is happy when you connect correct "ohms" cabinet to it... Atleast tube amps require right impedance, but I think there is only some minimum load that solid states will see? Dunno, but I'll bet someone has a better answer. Anyhow safe bet is to use impedance your amp/amps manual prefers.. Eg. in your case depending if your amp is set to 4, 8, or 16ohms... It needs cab with same impedance... Hope this helped... Dark
koko276
ohms
May 8, 2007 15:25:16 GMT -5
Post by koko276 on May 8, 2007 15:25:16 GMT -5
Yes, thanks a ton!
ohms
May 8, 2007 19:45:32 GMT -5
Post by ChrisK on May 8, 2007 19:45:32 GMT -5
It's always a good idea to have the amp's expected load be the same impedance as the load. That's why they're both specified.
ohms
May 12, 2007 21:00:12 GMT -5
Post by Ripper on May 12, 2007 21:00:12 GMT -5
Correct me if im wrong... Wasnt [glow=red,2,300]ooooohhmmmm[/glow] the first word uttered after the creation of the universe? Thus proving God is an electrician. Amen! ;D
ohms
May 15, 2007 11:39:31 GMT -5
Post by ChrisK on May 15, 2007 11:39:31 GMT -5
No, He's a baseball fan...
...'cuz it all started out with.....
......"In the big inning".............
mullnick
ohms
May 17, 2007 7:51:31 GMT -5
Post by mullnick on May 17, 2007 7:51:31 GMT -5
any one know about this ohm thing? if I have an 8 ohm amp does the cabinet have to be 8 ohms as well? I also have a cabinet rated at 16 ohms and I'm running my big amp through it and it is switchable between 4,8, and 16 amps. Any input would be appreciated on how to understand the matching. ;D Solid state amps should not be connected to any speaker less that the rated ohms for the amp. An 8 ohm output amp connected to a 4 ohm speaker causes more currect to flow out of the output transistors and can damage them... .. You can turn on a transistor amp with no speaker connected but tube amps do not like this.. They want to see a resistance.. It is ok to connect a 16 ohm speaker to an 8 ohm amp out. ( Edited to reduce the shouting effect of all caps.)
