R
Post by R on May 15, 2005 14:28:37 GMT -5
as you can tell from the title i have a marshall mg10cd I was wondering if it is normal for the amp to buzz when a certain note is hit because mine buzzes when i hit the "G" note im thinking that the speaker might need to be replaced i cant remember if it always did that but i noticed it after i bought a little marshall mini headphone amp just for fun and it buzzes for the "G" note too but that may be because its small ;D
Post by bam on May 15, 2005 21:01:38 GMT -5
Is it all G's or only low G ? If it's low G, that means there's something wrong with your EQ (i.e. the EQ is emphasizing G note). Try to re-tweak your EQ, if the amp's EQ is not enough, save a little bit more and get an EQ pedal.
Post by RandomHero on May 16, 2005 16:59:05 GMT -5
I have an MG and my guess is that the G is just hitting a resonant frequency inherent to the MG series' less-than--the-best speakers and comparatively shoddy cabinet quality. IE that frequency is rattling your amp.
One way you could tell, if you have the materials and time, is get a couple of c-clamps or pipe clamps and some board and find a way to "compress" the cabinet, IE keep pressure on it from two sides and hold it solidly together, then play through it. If the buzzing stops, then a crappy cab is the problem.
Post by JohnH on May 17, 2005 6:49:53 GMT -5
Yes Ive got one too! - (lets all admit it). Actually I think it is a great little box, plenty to scare the cats with while keeping friends with the neighbours. I don't get a buzz, its fairly consistent across the range. My main complaint is that the only half decent overdrive sounds occur in the first fraction of an inch of the gain control.
R
Post by R on May 22, 2005 14:23:20 GMT -5
when i add effects the rattle goes away its only when i use the amp in the clean channel that the rattle appears and its not all the time only some timees must be an amp grimlin
Post by bam on May 22, 2005 21:04:09 GMT -5
.. It means that it's all about EQ.
Post by karpetking on Oct 14, 2005 6:23:13 GMT -5
a bit late with this reply, i only just joined, but i had a marshall master lead mk ii (or something) 50 watt 2x12 all valve combo. it also had a wierd rattling, a bit like milk bottles clinking together, but coming out of the speakers. this also happened with the two lowest gs on the guitar. i found that it stopped after i turned it off, waited for it to cool down, and pushed all of the valves in. however, it started again after 5-10 minutes of playing. i don't know if they were coming loose, or if it just took a while for something to warm up before it went wrong. anyway, i never fixed the problem, and soon traded it in on a tele custom. i regret it somewhat though, it did sound REALLY good when you turned it up and played some rock riff through it. a bit loud for home use, though.
