Post by Runewalker on Jan 6, 2006 9:58:40 GMT -5
Twin Brain. Want to put a switch in that disables/cuts/hibernates (or whatever it does) 1/2 the power tubes. Torres Engineering has one: store.yahoo.com/torresengineering/50watswit.htmlBut given his prices on everything else, this can't be that difficult --- a $1 toggle and instructions = 1500% markup. Anyone run accross a how-to on this mod? RW
Post by UnklMickey on Jan 6, 2006 19:13:06 GMT -5
Twin Brain. Want to put a switch in that disables/cuts/hibernates (or whatever it does) 1/2 the power tubes. Torres Engineering has one: store.yahoo.com/torresengineering/50watswit.htmlBut given his prices on everything else, this can't be that difficult --- a $1 toggle and instructions = 1500% markup. Anyone run accross a how-to on this mod? RW well i haven't seen one, but my guess would be, at it's simplest it would be a DPST to disconnect the plates (pin 3) on one tube on EACH side of the output transformer. even if it is just a switch, that one will cost you more than a buck. there's 450~500 volts on those plates, so you can't use the cheap stuff. it may be even more complicated (a cheap switch and a 3DST relay) so the screen grids can also be disconnected at the same time) unk
