twostars
Post by twostars on Dec 17, 2005 13:09:03 GMT -5
This isn't a tube amp question since i use an H&H IC100S solid state head with and H&H 212DC 2x12" dual concentric PA cab.
firstly, ever since i've had the cab one of the cones has had an annoying buzz, practically a rattle that occurs when the cab is anywhere near a bass-heavy signal, either played through it directly or even through vibration from a nearby bass amp. The cone has no visible faults and delivers a high volume but it just rattles all the time, so recently i picked up a replacement cone (of the same kind, taken from the same model of cab) and swapped it in for the rattly one. Rattle problem solved. However, the speaker is definitely quieter now (such that i now have to crank the amp nearly half-way to match the volume i used to get at about a quarter/third-ish way) and is definitely shyer on the low-end than it was. Just to make sure i wasn't imagining it i swapped the old one back in, definitely louder and more bassy, but also very rattly. So i decided to stick with the new cone, but as my amp now has to be cranked harder it's actually starting to distort at a volume at which it was previously crystal clear. So here are my questions... 1) Could it be that there are some components in the amp head i could replace (without knowing a hell of a lot on the subject i'm thinking capacitors) that would allow it to provide enough power to this new speaker without the sound breaking up? 2) currently the 2 speakers in the cab are wired in series, the cab has 2 inputs on the back and the head has 2 outputs on the back. i'm wondering what would happen if i re-wired the cab so each speaker was separate with its own input and i connected it to the amp with 2 cables. would it make a blind bit of difference? thanks.
Post by bam on Dec 18, 2005 1:47:17 GMT -5
try your head on one of your friend's "battle-proven" cab. if it does good, then don't do anything to your head. Obvious, right ? .. hey, I mean that AMP head, *not* YOUR head :lol: .
About those speakers .. I think your speaker cone had a factory defect, either the old one or the new one. I'd suggest (again) that you go to one of your friend (or music shop) that has the same cab type, and try it first before taking any other action.
twostars
Post by twostars on Dec 18, 2005 4:51:14 GMT -5
thanks, i'll try it out with another cab. for the record, that head has always gone to distortion when turned up past half way, but with the other (rattly) driver it never needed to go that high. So it's like the 'new' driver is soaking up more power. I have another spare (i bought two spares) so i'll try that out, should eliminate the factory fault. the head and cab are both about 20-30 years old so not much opportunity to test against a brand new one. So as far as the head goes i believe it's had trouble providing that much power since as far back as i can remember, but until now it's never had to.
twostars
Post by twostars on Dec 18, 2005 4:56:10 GMT -5
looking back at my original post it could be perceived that with question 1 i'm looking to modify my amp head to make it more powerful. what i actually meant to imply was that it's an old head and that maybe replacing certain components would give it a new lease of life.
Post by bam on Dec 21, 2005 0:59:32 GMT -5
I personally think that's your old driver that goes into speaker DS (aka. rattling) more easily, and you shouldn't worry about modding that head until it is proven with another cab/speaker(s) that it's really powerless.
