Post by RandomHero on May 19, 2005 20:58:29 GMT -5
Playing around a while ago, I discovered that I can make a harmonic in a way I'd never thought of or heard before.
Harmonics die out if you rest your finger on them, right? Anchored by two solid ends they'll ring for a -long- time. I actually made a mistake in my fretting and got a harmonic sound out of what I thought was a normally fretted note...
Turns out I had been hitting the harmonic as I normally would, but then fretting the string immediately afterward, before the harmonic faded! Not only does the harmonic hold out for a long time this way, it can also be bent!
Has anyone else ever used this technique? It's a bit tricky at first but I've gotten to the point where I can do it every time I try, on any harmonic on the fretboard.
Post by Trey on May 20, 2005 11:55:34 GMT -5
Zakk Wylde does that kinda thing all the time, you should try sliding up or down the neck slowly while holding the harmonic...sounds killer.
Post by StratLover on May 22, 2005 21:26:35 GMT -5
This is a really CRISP sound especially at high gain and with a little chorus. ZAKK is probably the best at this, closely fallowed by the Satch and Steve Vai. I love the use of harmonics within the chord frame. When picking chords in a series and progression, try using this technique in the root of the chord with bends and a little dive bombing. You will find a whole new genre of your particular style! ;D ;D ;D
Post by bam on May 23, 2005 8:19:22 GMT -5
I think Satch & Vai improved the technique a bit by adding some whammy tricks.
Try it with stereo chorus and crunchy overdrive. Feels like being electrocuted, I think.
Post by StratLover on May 23, 2005 19:10:53 GMT -5
HA HA HAAAA---------Thats what I was trying to say "bam" ;D ;D ;D ;D ;D
Post by johan on Apr 7, 2006 15:35:24 GMT -5
Wow, I'm by no means into metal, but (read: that's why) this was a really useful post for me. I learned something new.
thanks, RH, great hint J
Post by guitardoode on Apr 10, 2006 10:43:14 GMT -5
I quite often mess about on my JS signature doing that stuff, it really is quite a laugh, it's like doing satch's on stage natural harmonics by the bridge then giving the trem arm a nice good tug thingy, What a lovely tone ;D I love doing that but i have the Cheaper version and the arm just goes all loose and i need to tug it so hard to get the same tone... and im scared of doing that.... (I snapped an arm doing it after a month of buying the thing!!!) I still trying to figure out if it has a proper name, i personally named it the whammy scream
Post by strathappy on Jul 22, 2007 22:04:13 GMT -5
Good harmonic tips, all sorts:
