Post by mike on Sept 18, 2005 20:08:41 GMT -5
I have a Boss power adapter and I want to use a 1spot or godlyke daisy chain with it so I can use it to power more than one effect at a time. Does anyone know if either of those chains will link up with the Boss power adapter?
Thanks
Post by erikh on Sept 21, 2005 13:32:18 GMT -5
As long as the barrel that will accept the BOSS adapter barrel (2.1mm), I don't see a problem.
erich0316
Post by erich0316 on Oct 8, 2005 8:43:46 GMT -5
Make sure the "Tip" orientation is correct, for polarity. The device you are plugging in to should have a little symbol with a positive & negative symbol. Use a voltmeter to determine whether the tip is positive, or negative. ( I am pretty sure the Digitech pedals, for example, take a tip-positive, barrel-negative configuration)
Post by erikh on Oct 11, 2005 12:49:20 GMT -5
Make sure the "Tip" orientation is correct, for polarity. The device you are plugging in to should have a little symbol with a positive & negative symbol. Use a voltmeter to determine whether the tip is positive, or negative. ( I am pretty sure the Digitech pedals, for example, take a tip-positive, barrel-negative configuration) This is soley dependent on the adapter being used, not the daisy chain. The Digitech distortion units are tip negative, same as BOSS. It is good info to know nonetheless.
