Post by bluesjunior on May 19, 2008 5:04:51 GMT -5
Wondered if anyone here can give me any help or advice on this question?.
While I was restringing and checking the intonation on my Strat yesterday my dog walked into the wire from the 9v adapter to the AX-12 tuner resulting in it being pulled off the table and landing with a clunk on the floor.On checking it I have power on and the other three buttons light up what they did before both with the adapter and also with a 9v battery but it isn't tuning anymore either with the inbuilt mic on an accoustic, or with an electric using the jack socket. The bypass works as I can hear sound from my amp with the tuner connected in line both switched on and off but I seem to have no tuning activity.
I'm afraid I know next to nothing about electronics. My instincts lead me to believe something, ie a fuse or somesuch has blown but I have opened it up and cannot see anything obvious. There are no fuses as I perceive them to be seen and no breaks or such to be seen. I can solder and know how to rewire a guitar but haven't a clue what to do here other than put it down to experience, buy a new one and be more carefull in future.
Just thought I would ask some advice here before deciding. Thanks in advance for any help offered.
Post by newey on May 19, 2008 5:38:11 GMT -5
Blues-
Afraid I can't be much help as I've never seen the innards of one of these. Since the unit powers up, it's not a loose connection to/from the battery or 9V input jack, and the in/out jacks must be ok if you get signal to the amp.
Which means you probably banged something loose on the circuit board (or, rather, the dog did . . ). You'll need to post some photos of the innards, and you'll need a multimeter to check the various components. Post photos, sometimes all it takes is another set of eyes to spot the problem. You may also need to de-mount the circuit board from the case so that you can see/photograph the backside of it, depending on how it's mounted in there.
Since you're looking at having to buy a new one anyway, no harm in tinkering with this one, maybe you'll get lucky and get it working again.
AFAIK, there wouldn't be any fuses in there.
Post by bluesjunior on May 19, 2008 8:52:04 GMT -5
Thanks very much for the reply Newey.
My son told me of a new electronic repair place which had opened on one of the local trading estates. I gave him a ring and explained what had happened and although his business is mostly Hi-Fi repairs focussed he said to bring it in and he would have a look at it.
Just have to wait and see what he can or can't do now.
Post by ChrisK on May 19, 2008 15:39:15 GMT -5
I would suspect that a component or its mounting onto a printed circuit board has broken from the impact.
Is there anything loose or rattling around?
