Post by ChrisK on Sept 19, 2006 17:33:14 GMT -5
Post by ChrisK on Oct 13, 2006 12:09:56 GMT -5
A general layout template.
Post by ChrisK on Jul 5, 2007 0:21:31 GMT -5
Here are three Strat templates for the underside of the pickguard. One is for the standard 3/5 way lever switch (DP3T, shorting in them there notch positions), one is for the standard 4 way Tele lever switch (DP4T), and the last one is for the 5 way super switch (4P5T). Note that each pot is shown as a dual concentric (or blend) with DPDT push/pull or push/push switch. This configuration does not exist, but allows one to reuse the same symbol for all existing potentiometer-based components. The standard 3/5 way lever; The Old Template The standard 4 way Tele lever; The 5 way super switch.
Post by ChrisK on Jul 18, 2007 11:50:53 GMT -5
Import (boxed) 3/5-way Lever Switch correlated to 3/5-way Fender-style lever switch. Note that it was easy to discern the switch logic of this unit before someone posted the link to the datasheet that I modified because one "can see thru the PCB".
