Post by flateric on Jan 23, 2009 11:40:09 GMT -5
If I used 2 DPDT switches to make an A/B X/Y box, where the first switch chose one of 2 inputs and the second switch chose 1 of 2 outputs, this should be a pretty straightforward wiring, right? The other half of each DPDT switch could then be used to switch corresponding LED's as indicators. Would the LED's + battery circuit need their own separate ground or could I connect to the common ground wiring from the 4 jack sockets?
(The purpose of the box woould be to allow to switch quickly between 2 guitars on stage and choose output to amp or mute the amp and go into the tuner.)
Post by JohnH on Jan 23, 2009 16:03:50 GMT -5
Seems like it should work. My thoughts would be:
Does the switch controlling the output need a third pole, to shunt the unused output to ground, which is quieter than leaving it hanging, especially if amp is on high gain? Power can be engaged using a stereo jack on whichever of the four sockets you think is most convenient for plugging into (assuming you might leave the box set up with most of its leads for a period between use). But maybe consider also having a separate power switch, to save battery life when you dont need the LEDs? Your switching of course, will still work without power. As to a common ground for the signal and LED power - I think its OK, certainly no problem while playing. I wonder if the surge of power through the LEDs when switching will induce a small 'click' in the signal? I'd guess it shouldnt be much different from LEDs in a normal stompbox however. Do you want a dc power socket as well, to run the LEDs from your stompbox supply?
Post by flateric on Jan 23, 2009 18:30:33 GMT -5
I guess a 9V battery would last a good few months only powering 4 little LED's, only 2 would be on at any one time, so maybe a DC mains socket is overkill for low current drain. Can you help me understand the third pole/unused output to ground issue? Here's the rough schematic I scribbled out:
Post by flateric on Jan 23, 2009 18:53:20 GMT -5
Is this what you mean? Is there a benefit doing this to the input stage as well?
Post by JohnH on Jan 23, 2009 21:46:40 GMT -5
That looks like it would work - both versions. The thing about grounding the unused output, is like when you have a guitar cord plugged to the amp, but no guitar - it can pick up a bit of noise, but if you ground the tip, its dead quiet - it depends how much gain you are using.
Theres no point in grounding the unused input.
How long the battery lasts depends on the LEDs. I have some that use less than most, and run nuicely at about 2mA. Two of those might work well for about 100 hours or so with a 9V battery.
Post by flateric on Jan 24, 2009 10:30:24 GMT -5
Here it is finished and all functioning correctly. Thanks to JohnH it is very quiet and no 'popping' when the channels are switched. Perfectly in time for tonights gig.
Post by JohnH on Jan 24, 2009 14:10:40 GMT -5
Nice quick work! I think I want one! Its amazing how those jacks and switches fill up the box. +1 to you for presenting a useful but simple device.
