Post by ashcatlt on May 30, 2009 0:50:22 GMT -5
For a while now I’ve been thinking about building a high quality power supply for my pedals. I looked over schematics involving transformer isolated outputs, regulators of various sorts, current limiting…
…and then I realized that I’ve been using the same powered pedal board for over 10 years now. I’ve used it in both recording and live situations. I’ve never had any reason to complain about the power supply. Maybe I’m just used to it, but then again it must be good enough for me.
Unfortunately, it’s a soft-sided case. It’s falling apart at the seams, and must be replaced. It’s also not particularly convenient when I’m trying to power pedals for several different instruments. And then there’s this…
Notice the nasty discoloration of the resistor and its attached wiring? I have no idea when, how, or why this happened. I guess that’s a good thing, in that it didn’t cause a big enough fire to get my attention.
So I’m going to re-house it inside a tuna can. Actually, I guess it was crabmeat. Our friends in the Real World might call this a tin, but it seems to be made of steel. At least, it sticks to magnets.
I’m also going to replace that resistor. Which leads to the big question I have:
What is a good value for this resistor?
I just can’t get my head around the color codes. I’m never sure what color they think I’m looking at… Anyway, I’m pretty sure that - in this case - the colors I’m seeing are not the ones that were there when it left the factory. I snipped it out of circuit and it metered out at 10 Ohms. Yes, no multiplier.
The BAC you can see in the picture says it’s 6800uF 16V. My meter only reads up to 4000uF, so it is not helping me. I thought I might devise a test where I put it in Ohm mode, time the thing as it rises, and use the slope of that line to determine the capacitance… It’s a big slow cap and I don’t have the time or patience for that.
I couldn’t get well-focused pics of the rest of the layout, but there are 6 x 1/8” TS phone jacks. Close to each of these is a tiny little cap between the + and – busses (the top and bottom of the PCB). My wife said she thought they said “104”, and my meter says 100nF. I’ll have to tell her she was right.
The basic wiring is like so:
I’m ignoring the LED and it’s current limiting resistor, since they’re not going to make the trip.
And then there’s the component - labeled C6 - in the place where one would expect to find a capacitor beside one of the output jacks. It looks exactly like a diode to me. Also seems to act like one as it presents infinite resistance in one direction, and relatively little in the other. The print on it is too small to read. I tried to shoot it with my digital camera and apply forensic image enhancement techniques. Failed.
BTW – I have no idea what kind of load will eventually be applied to this circuit. I use mostly Boss pedals, but it could be anywhere from 1 to 5 at any given time, and they could range from basic boost to digital pitch shift and who knows what else. I likewise have no way of predicting the minimum operating voltage for any of these. Digital pedals seem to be pickier. I’d like to get somewhere close to 9V at the outputs. The power supply is rated at 9V DC and somewhere up to 1A (don’t have it close right now, but it’s plenty, or easily replaced).
