Post by rabidgerry on Jan 4, 2010 10:04:28 GMT -5
Hello, I've a few questions I'd like to hopefully have explained.
I've been reading through some of the troubleshooting guides on Guitarnutz website and came across a few stumbling blocks to do with noise.
Now one of these is to do with "PROPERLY SHIELDED" guitar cords or leads.
Any music cable I own says it is shielded, i.e "noiseless" (usually) somewhere along the side of the lead or else it says "shielded".
However I have discovered through use of the "Troubleshooting Noise" guide on guitarnutz that my cables aren't actually shielded according to this guide and one of the tests to prove if guitar leads are "properly shielded or not". This is the resistor test of placing a 10k resistor across the connections of a guitar cord.
"Unplug the other end of the cord from the amp (or the stomp box it is plugged into).
If the noise level dropped significantly the problem is the cord. Replace the cord. Note, it's not unusual for an unterminated cord to pick up some noise, but if the cord is well shielded it shouldn't pick up much. If you want to be certain whether the noise is coming from a poor cord or just because the cord is unterminated, you can place a 10k resistor across the free end (without holding it in place with your fingers, which will introduce noise). If you do a lot of this sort of thing I recommend a 1/4" inline jack with a 10k resistor across the terminals.
If the noise level didn't drop significantly, the cord is okay, proceed to the next step. "
So I did this resistor thing right and yes the noise got quieter, so if you read the quote above it says
"If you do a lot of this sort of thing I recommend a 1/4" inline jack with a 10k resistor across the terminals."
Do a lot of what sort of thing? huh???
Is this statement trying to tell me that putting a 10k resistor across "poorly shielded cables" is the answer to making them quiet?
Please can someone clear this up for me. If this is what it is implying then rather than buy a load of really expensive "quiet" guitar leads then I', just gonna wire a whole pile of 10k resistors to my leads since it made it quiet whilst the cord was unterminated.
Ok next up, why do all my "probably lesser quality" guitar cables say they're shielded if they are not actually?
and what makes and qualifies for a good quality, quiet and properly shileded guitar cable? Any links to brands of cables please list for me as that will be useful also.
Ok more questions.
I shielded partially the inside of an old zoom multi effects pedal I own just to see if I could get away with reducing the noise reduction setting a little. From my early tests it didn't make any difference. However when I attached a wire to the baseplate of the pedal (which is metal and in connection with the internal shielding) and then attached the other end of the wire to the ground connection of a guitar cord (which was plugged into the input of the pedal) noise dropped a noticeable amount (not tonnes but certainly a useful amount). So would this indicate that I need to attach the shielding to the ground of the input?
I'm also very aware I might blow myself up or die from electric shock so I'm kinda afraid to do much more. Is there a danger of the shielding electrocuting me?
By the way I shielded this pedal as its plastic housing all apart from the metal baseplate.
Thanks for any assistance people I hope you all had a good Christmas and New Year
Ok more questions.
