maxcalibur
Half Bullet, Half Sword.
Post by maxcalibur on Jul 21, 2010 12:13:44 GMT -5
Ok, so should I angle the bridge as is done on quite a few Gibson guitars? Is it something I need to somehow test out or is it safe just to place it perpendicularly to the neck at the right length? I am gonna install a Bigsby with a tune-o-matic bridge probably. The nut is shown below. What I meant is should it sit flush against the fretboard and the headstock? I am gonna get a new graphite though. I could make a very slight slot for it to sit in but going down much lower would be hitting the truss rod.
Post by chuck on Jul 21, 2010 14:55:10 GMT -5
usually they sit flush
maxcalibur
Post by maxcalibur on Jul 21, 2010 17:50:00 GMT -5
I thought so, I might file a shallow slot for it to sit in. Still not sure about the bridge thing though. Have been reading a lot about it but lots of conflicting views as with these things!
Post by chuck on Jul 21, 2010 18:17:49 GMT -5
there are conflicting views about EVERYTHING ... even the statement i just made . if your bridge has a lot of saddle adjustment travel you can make up for a slightly imperfect bridge angle. note the words "lot" , and "slightly"
maxcalibur
Post by maxcalibur on Jul 22, 2010 3:29:45 GMT -5
Ok. Well I'm thinking about a Gotoh or Schaller roller bridge. What do you think about those?
Post by chuck on Jul 22, 2010 13:36:49 GMT -5
Gotoh has a good reputation , and i love Schaller stuff so either should be fine. i would personally go for Schaller , but if i found a great deal on a Gotoh i would be happy to put it on my guitar.
Post by ashcatlt on Jul 22, 2010 14:52:05 GMT -5
I think that, rather than filling a slot for the nut, you'd be better off sanding down the flat side of the nut to make it a bit lower.
maxcalibur
Post by maxcalibur on Jul 22, 2010 19:06:23 GMT -5
Yeah. I think that's probably a better option. I can always get a new nut if that goes wrong!
With regard to bridges I'll see what I can get a good price on if either will be reliable.
Post by naturalborn on Sept 2, 2010 16:41:57 GMT -5
If still considering staining, a cheap quick option is leather stain. It pretty much turns anything jet black if you put enough layers on. It would more than likely cover the grain so the wood dye by far best option.
If you want to see the grain still, generic spray paint would work if you spray on REALLY light layers from a bit of distance but make sure you have some practise spraying first if never done so before and look up about technique as you would easily cover it altogether otherwise.
In regards to fear of scratches/dents, if you do a very thin layer of spray can clearcoat, it'd do the job. I have a maghony RG in black quite thick stain, its not scratched or dented and I've been really abusive to it.
