col
format tables
Post by col on May 6, 2024 16:17:18 GMT -5
Hi JohnHI do not mean to perform surgery on the second pot to change the wafer. It would be dual-ganged pot, one 500K, and the other 2meg (or possibly 1meg). I've been working on an idea which requires the use of dual-ganged 500k/2meg pots and wondered if your circuit could be incorporated to make use of the 2meg pot. Alternatively, might a resistor in parallel (680K) between the zero end of the 2meg pot and its wiper provide a workable sweep? Though, I am not sure if I have enough switch poles available to achieve this and the other switching the circuit would require. If this is not achievable, I'll publish my circuit (without your treble bleed) soon.
Post by JohnH on May 6, 2024 16:23:40 GMT -5
Ok, well given a few days I can check that out using GuitarFreak. As a starting point, would the 500k and 2M wafers both be log taper?
col
format tables
Post by col on May 6, 2024 16:40:19 GMT -5
Ok, well given a few days I can check that out using GuitarFreak. As a starting point, would the 500k and 2M wafers both be log taper? The guitar pot can be either (but probably log). But the bleed pot will be linear. Thank you, JohnH.
col
format tables
Post by col on May 6, 2024 16:45:59 GMT -5
Urgh. I had missed that you used a log pot in your bleed circuit, JohnH. I do not wish to see you go to a lot of trouble. If you like, in a day or two, I can post my design (with a variant incorporating your bleed circuit) and you can then assess if it is worth investigating component values to hopefully make it work properly.
Post by JohnH on May 6, 2024 16:56:51 GMT -5
ok thanks, sounds like a plan!
