Post by diminitive on May 3, 2011 10:05:29 GMT -5
Okay, here we go. At every setting with the pot pushed, everything works fine.
Pulled (position 1 is at the NECK): 1: 1 is N, 5 is nothing, 10 is nothing. 2: 1 is B+N, 5 is B+N, 10 is B+N. 3: 1 is nothing, 5 is nothing, 10 is B. 4: 1 is B, 5 is B, 10 is B. 5: 1 is B, 5 is B, 10 is B.
I'm confused..
Post by JohnH on May 3, 2011 15:23:54 GMT -5
OK, well that is good info because it shows that rw M Pup is not getting connected properly in series, and B is not getting faded down when it should mode. I will think whether there is a wiring glitch that could have occurred to explain those results. Meantime, please check it all over one more time with the diagram
These blenders definitely do work, so we will get this fixed! cheers John
Post by diminitive on May 3, 2011 16:05:27 GMT -5
Well, it probably has something to do with the 10k resistor soldered over the cut.. My dad proposed this as a solution to the problems that first arose. Unfortunately, I can't replicate those right now. Hopefully we'll be able to continue to work on the guitar this weekend.
