Post by sbgodofmetal on Jun 16, 2011 13:01:41 GMT -5
Now how would one incorperate a level pot to this??? Would it be wired to a pot like a tone control? volume control?? Both??? Or am l gonna need something else?
Post by sbgodofmetal on Jun 16, 2011 13:24:50 GMT -5
This is a DP6T rotary, and from the LEDs i'd say its active but switching to schottky (LVD) diodes and dropping the LEDs to add a few more diode combinations would this work passively???
Post by ashcatlt on Jun 16, 2011 13:55:48 GMT -5
Probably work better active with some significant gain before hand.
To vary the amount of clipping either vary the gain at that stage, put a normal volume control before this, or put a variable resistor in series with that wire to the PCB.
Post by sbgodofmetal on Jun 16, 2011 14:22:54 GMT -5
Ok thanks ash, would adding this to a booster circuit like the electra distortion l posted before do the trick?
Post by ashcatlt on Jun 16, 2011 15:17:40 GMT -5
Any kind of booster before it will work.
My challenge to you is to use less diodes to accomplish the same results. Right now you've got a lot of redundancy.
