Post by thetragichero on Aug 12, 2011 11:15:00 GMT -5
not sure where this should go, so i'll put it here and it'll be moved if i'm wrong...
anyway, assembling my first p(arts)bass, and the tuners i have (gfs wilkinson) are quite a bit smaller than the 11/16" holes in the headstock if i had to guess, there's a good 1/16-1/8 inch gap all the way around the peg are there bushings for this purpose? is this even anything i need to worry about (it attaches with 4 screws on the baseplate)?
thanks in advance for the help!
Post by cynical1 on Aug 12, 2011 11:25:11 GMT -5
Yes. Do a quick Google search for "Bass Tuner Bushings". Check the diameter of the tuner hole in the headstock with the diameter of the shaft on the actual tuner you have in hand. There are several sizes available, but they usually do the job with a minimum of hassle on your part. HTC1 EDIT: www.buzzardsbass.com/parts/tuning-machines/parts.html
Post by thetragichero on Aug 12, 2011 22:16:42 GMT -5
hey the tuners came with bushings, they were at the bottom of the box. please delete this thread
Post by cynical1 on Aug 12, 2011 22:21:30 GMT -5
Yes. Do a quick Google search for "Bass Tuner Bushings". Check the diameter of the tuner hole in the headstock with the diameter of the shaft on the actual tuner you have in hand. There are several sizes available, but they usually do the job with a minimum of hassle on your part. HTC1 EDIT: www.buzzardsbass.com/parts/tuning-machines/parts.html...or you could just look in the bottom of the box... HTC1
Post by D2o on Aug 13, 2011 10:27:09 GMT -5
...or you could just look in the bottom of the box... HTC1 Pure genius! Kyle says he is "prowd of yous guys".  Have a great weekend everyone - and, I guess for John x 2 and the others in Oz, have a great week! D2o
Post by newey on Aug 13, 2011 12:33:38 GMT -5
We don't delete things around here just because someone made a mistake.  In the immortal words of The Hombres, we "Let It All Hang Out". Our mods, and our postings, come with "warts and all"!
Post by cynical1 on Aug 13, 2011 13:06:25 GMT -5
hey the tuners came with bushings, they were at the bottom of the box... Don't worry about it. As the years advance, and CRS begins to set in, things like this will happen all the time. Tools will instantly disappear, then magically reappear...reminder notes become useless as you forgot where you put the damn piece of paper... Eventually, if you hang around long enough, you may become judicial in your time...hope springs eternal... Happy Trails Cynical One
