Post by cynical1 on Feb 22, 2012 7:54:07 GMT -5
I have a need for a power box running off UK 240V AC to power a pedal board and give 3 different voltage outputs; its 9V needed for 4 stompboxes, then 12V for some LED strips and higher voltage (can't remember if its 18V or 24V) to power an EHX bass micro synth pedal. Where would I start? Well, you could combine multiple outputs to gain your desired output voltages from the box and regulate them back accordingly. The basic Spyder design can be constructed from the transformer Weber offers, or a series of individual transformers. That may, or may not be the best way to go depending on the amperage draw from your effects, but you can peruse what Weber has to offer here: taweber.powweb.com/store/magnetic.htmThe European version of the transformer I have is a WPDLXFMR-2. Per Weber: "Pedal and effects power supply transformer, Eight 11 volt, 300mA windings and one 9 volt, 2 amp winding. 120-220-240 VAC input."Hope some of that helps. Happy Trails Cynical One
