Post by JohnH on Jan 1, 2012 18:13:08 GMT -5
Ok thats great!
Thinking about any practical tips:
The 500k pots are best as log taper for both There's a bare wire shown dotted. That carries no signal, but grounds the bridge and strings and the pot cases. On p/p pots, there is usually a handy tag at the back of the switch, which is much easier to solder to than the case of a normal pot, so that is what that dashed wire is intended to connect to as it passes each pot With three pups all by Dimarzio, you should have no phase and hum issues, though you might get a bit of hum remaining when coils from different pups combine Unless you can work on a pickguard removed from the guitar, I suggest making a card template to do most of the wire-up away from the guitar, starting with the wires across the 5-way switch, then the pots. Pickup wires can be attached when controls are mounted in the guitar Are you going to shield the cavity first? Its a good idea if you do If you have a multimeter (or get one), its good to measure the resistance of each coil first, then when you test it later, you can troubleshoot by working out the expected single, series and parallel resistances (we will help if needed) These more complex designs often don't work first time, even with a design built before, so anything that helps troubleshooting is valuable.
Good luck and post any problems if you need help.
Post by reTrEaD on Jan 2, 2012 11:08:43 GMT -5
Thinking about any practical tips: One issue not mentioned was the orientation of the pickups. It won't affect the hum canceling, but it will affect the sequence of the single coil selection. DP193 Air Norton (Neck) DP187 Cruiser Bridge (Middle) DP161 Steve's Special (Bridge) The Air Norton has a screw coil and a slug coil. It will be easy to recognize the south (screw) coil and orient the pickup with the south coil closest to the neck. The Cruiser and Steve's Special won't be so obvious. The Cruiser is a twin rails type and the Steve's Special has hex socket screw type pole pieces for both coils. Check with a magnet and find the same (south) polarity as the screw coil of the Air Norton. That coil should be closest to the neck.
stratobob
Post by stratobob on Feb 3, 2021 2:36:06 GMT -5
Happy New Year everyone!!! I appreciate the help! These are some really nice ideas. I am going to tryout JohnH's 3x5 Rev. A. I like having all of the available options. I will give feedback after I get it up and running. Happy New Year Axeman happy New Year to all of you, Axeman, it's been 9 years since your last message so I'm wondering if you finally did it or not, if you liked it or not and if you kept it like moded or not. If you ever have any pics of it could you please share with us? If anybody has any pics of of this set I'm very curious to see it for real. Thanks, Stratobob
