Post by flateric on Mar 30, 2012 16:06:38 GMT -5
This was built for some raucous bass fuzz, based on the Zvex Woolly Mammoth, a simple little veroboard build with some evil sounds, uses 2 x 2n3904 transistors to generate the nastiness. Heres a rather crude youtube soundclip
Post by reTrEaD on Mar 30, 2012 18:06:18 GMT -5
based on the Zvex Woolly Mammoth Don't say that. Zach might come after you with lawyers in tow.
Post by flateric on Mar 30, 2012 18:12:32 GMT -5
using a basic fuzz circuit thats been kicking around for 35 years, a home hobby build, I hope his lawyers have better things to do with their time...
Post by cynical1 on Mar 30, 2012 18:15:17 GMT -5
Well, that was certainly enough fuzz for two bass players... What does it do if you feed an overdrive into it?
HTC1
Post by flateric on May 1, 2012 10:45:35 GMT -5
gotta give that a try! Thinking of rebuilding with a blend knob added for bass to mix in some dry signal, might make it a bit less Trunk-in-yer-Face
Post by yakkmeister on May 1, 2012 22:02:49 GMT -5
You know what would make a great fuzz pedal? A QuadraFuzz pedal! ^_^
Post by ashcatlt on May 1, 2012 22:45:13 GMT -5
I'm thinking this is one of those fuzzes which sort of expects to load down passive pickuls attached to it. A low input Z kills a bunch of treble on the way in, so that less tone shaping is required inside the pedal.
After a buffered OD it may start to get a bit fizzy and splatty. Course, there's a place for that kind of thing, too...
Post by flateric on May 2, 2012 5:31:40 GMT -5
Some of the Zvex pedals have a reputation for sounding awful with an active guitar/bass input. I tried this one with both active and passive basses and it sounds immense, too big for me to make use of in my band, but maybe with a blend knob, it might tame it sufficiently for some RATM or Muse numbers
