Post by newey on Aug 17, 2014 20:08:50 GMT -5
jimdrack-
Hello and Welcome to G-Nutz2!
This is not comprehensible. I think there's a language problem, or perhaps poor translation software. In any event, we'll need you to clarify this.
jimdrack
Post by jimdrack on Aug 17, 2014 20:54:02 GMT -5
jimdrack- Hello and Welcome to G-Nutz2!This is not comprehensible. I think there's a language problem, or perhaps poor translation software. In any event, we'll need you to clarify this. hello if the diagram that guitar run? I would like to hear
Post by haydukej on Aug 17, 2014 22:58:48 GMT -5
hello if the diagram that guitar run? I would like to hear Coming from the midwest, I can translate poorly-translated English. I interpret this as if the said wiring diagram was actually implemented, Jim would like to hear some sound samples of it. Adam's last post on this diagram was in September 2013 and his last log in was April of this year, so outlook not so good.
jimdrack
Post by jimdrack on Aug 17, 2014 23:18:20 GMT -5
hello if the diagram that guitar run? I would like to hear Coming from the midwest, I can translate poorly-translated English. I interpret this as if the said wiring diagram was actually implemented, Jim would like to hear some sound samples of it. Adam's last post on this diagram was in September 2013 and his last log in was April of this year, so outlook not so good. I want to know if the plot worked, if there was a problem and a video later to see if it worked sorry for my translation
jimdrack
Post by jimdrack on Aug 17, 2014 23:20:42 GMT -5
hello if the diagram that guitar run? I would like to hear Coming from the midwest, I can translate poorly-translated English. I interpret this as if the said wiring diagram was actually implemented, Jim would like to hear some sound samples of it. Adam's last post on this diagram was in September 2013 and his last log in was April of this year, so outlook not so good. I want to know if the plot worked, if there was a problem and a video later to see if it worked sorry for my translation I like the versatility of this diagram but really want to know if it worked
Post by JohnH on Aug 18, 2014 8:07:44 GMT -5
Although I see we had quite a long discussion about this, I don't think we ever heard whether or not it was built successfully. It is a complex design and I confess to not having checked the final version myself. What is it that you are looking to achieve with an HSH wiring?
Post by newey on Aug 18, 2014 8:17:54 GMT -5
jimd-
As haydukej noted, we never heard back from adam to know if he implemented this design or not. And no one ever double-checked his diagram, either. As adam himself said, it can give you a headache just looking at it!
I've just now tried to trace this out, and it doesn't look right to me, I don't think the series-parallel switching is correct with the individual coil cut switches.
This is a very complex scheme with many redundant switching options. JohnH and I both tried to convince adam to simplify this a bit, but he wanted exactly what he wanted.
Part of the problem is the use of a wiring diagram instead of an actual electrical schematic. With a complex design like this, ideally we would have a schematic first, which we could then much more easily check for workability. The actual wiring diagram is then drawn from the schematic once we know the schematic is good to go.
adam never did explain into what sort of a guitar he was intending to install this wiring. I have my doubts that all of this switching would fit into any standard cavity on a Strat or any LP type guitar.
So, jimdrack, rather than work on this further without hearing back from adam, perhaps if you could tell us your intentions we can point you in another direction to a scheme that we know will work.
