whynot
Post by whynot on Nov 6, 2005 10:43:37 GMT -5
my firend has viven me a columbus guitar looks the same as slash's out of guns n roses but there is 3 switches between the knobs 1 2 way and 2 3 way the neck pickup is a dimarzio humbucker and the bridg one is a kent armstrong hro-1 there is a yellow blue green and bair wire from the neck pickup but the bair and green are solderd 2geather to one of the 3 way switches and the rest have come off the brid pickup has bair solders do the back of a pot green black red and white solders to a 3 way switch the 2 way is conected to one of the 2 way switches and ther and 1 volume pot anyone know what i can do with this wireing setop i dont mind compleatly striping this down and starting again it cost me nothing because the neck isnt attached whitch is a easy job to do any wireing plans for this would be grate i want to play rock music guns n roses acdc pink floyd metalica ect o by the way there is a rythem and treble 3 way switch conected to it some how
whynot
Post by whynot on Nov 8, 2005 17:19:38 GMT -5
think i worked it out 1 humbucker is a dimazio super distortion at the neck and the other is a kent armstrong hro-1 at the bridge there is 2 3 way switches and 1 2 way 2 volume 2 tone and the rythen treble 3 way switch the kent armstrong wireing is bair green blackred and white the dimazio is red yellow blue green and bair with the green conected to the bair i dont want to remove the switches because it will destroy the paintjob but i want them in use i was thingking can i have on each 3 way switch single coile standard humbucker and then coile reverce with the 2 way acting as on off so when its off its a standard guitar the 2 switches dont work but when its on it uses the switches
