Post by vonFrenchie on Jun 14, 2016 22:17:22 GMT -5
Hey everybody, I recently sold my Mastotron. I was looking at building a new fuzz pedal and I couldn't decide which pedal to build. I realize that with a few wiring tricks I could make an extremely versatile fuzz pedal. I am basing my pedal off the Multi-Face, but I would like to find a way to add a few features from the Mastotron. I was fairly fond of the Relax/Push knob and the subs switch. The one difference between the Multi-Face build and this pedal is the addition of 2 rotary switches controlling the transistors at Q1 and Q2, a DP3T switch for C in, and a DPDT switch for C out. I have a few obstacles to deal with first. Would I have to completely isolate each transistor or just the center lead of each transistor? I don't want any unnecessary noise coming from improperly isolated transistors. Secondly, how would I go about adding the subs switch and the Relax/Push potentiometer? I have a feeling that the subs switch on the Mastotron and the C out have fairly similar functions, but that is just going off the perfboard layouts. I have no idea how the Relax/Push pot works. Thanks in advance for the help, vF Guitar FX Layouts - MastotronThe Multi-face
Post by vonFrenchie on Jun 15, 2016 14:41:28 GMT -5
I drew up a couple of schematics. First is the original Multi-face schematic Now, I used this schematic for the Mastotron. It is slightly different than the stripboard layout I posted in the first post. I took out the tone circuit, Subs, and the Relax push pot and added them to the original Multi-face to get this Sorry that the schematics are messy and kind of jumbled up. I haven't drawn any schematics in years. Does anyone see any flaws in this plan?
Post by newey on Jun 15, 2016 21:50:15 GMT -5
VF- Sorry, I don't have any answers for your questions, this is out of my depth. But someone will be along soon, hang tight. I just wanted to say welcome back, we haven't heard from you for a while. I trust all is well in Beertown?
Post by vonFrenchie on Jun 16, 2016 1:14:52 GMT -5
Thanks! Everything is going well. So well that I haven't had time to work on any music related projects. I'm in the process of restoring a motorcycle. It seems like the forum is fairly dead these days. Every time I've checked for responses I was the only one on. What happened? Also, how is everything on your end going?
Post by newey on Jun 16, 2016 6:11:27 GMT -5
All is well here. We're older but not necessarily any wiser.
You're right, things have slowed quite a bit, and I don't know why, unless modding guitars is fading in popularity.
Post by sumgai on Jun 16, 2016 9:25:03 GMT -5
vF,
Hey, good to see yer face around here again!
As to the "loneliness", I can only say that it happens in phases. These days, only a handful of guitarists practice Veni, Vedi, Velcro*, but history says that'll change up soon enough.
* I came, I saw, I stuck around.
Post by vonFrenchie on Jun 16, 2016 13:14:27 GMT -5
Sorry for not sticking around. Though I haven't forgotten about you guys. I came, I saw, I traveled around for a while, and I realized what I was missing.
Post by ashcatlt on Jun 21, 2016 11:38:34 GMT -5
I'm sorry to say that thing is all messed up. I'm not sure what it'll do, but it won't be what you intended. You've got the Multiface wrong to begin with. The bias trimmer/gain structure is shorted, so it can't do anything, and that second transistor will pretty much just run flat out all the time. It should be biased somewhere near the middle of the battery just from being DC coupled to the previous stage, so it should "work", but... Move that 100K resistor to the ground node, and snip that wire from ground to where the 100K hits now. Your frankenstein thing is all wrong. The Trim/Gain structure won't affect bias or gain, but it will mess with the action of your tone control in somewhat complex ways. You can't share that cap, even though it's the same value. They're not supposed to connect to the same place. The way this should work is that the trimmer sits between the bottom of Q2 and ground, and sets the DC bias/gain, and is used to adjust the symmetry of the clipping action. The gain pot in series with the cap is in parallel with that trim pot. They allow higher frequencies to bypass the trim pot and have more gain than the DC/lower frequencies. I honestly haven't checked much of the rest of the circuit because really none of the rest matters until you fix this bias/gain structure. Edit - after reviewing this pefboard layout, which is almost just a schematic on perf, I changed my recommendation on how to fix your scheme.
Post by vonFrenchie on Jun 26, 2016 16:34:08 GMT -5
That was a complete brain fart on my part. I drew that 100K resistor wrong once and never went back to check my work. So I can't connect the 22 uf cap to the 5.1k resistor. Should just ditch the connection, add a cap and connect it to the other side of the gain pot, or will there need to be a completely different connection?
Thanks for the critique. I'm going to draw up another draft.
