Post by antigua on Nov 5, 2016 22:18:35 GMT -5
www.lollarguitars.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LGP&Product_Code=238&Category_Code=strat-pickupsThe Lollar Tweeds are among the lowest wound Strat sets on US boutique pickup market. The Strat set that I've measured that comes closest to date is the GFS Boston Blues. Few Strat sets have loaded (470pF added) resonant peaks that go much beyond 4kHz. A lot of Fender's sets are almost wound low enough that they should break the 4kHz mark, but they capacitance tends to bring them down to the high 3kHz range. The Boston Blues has an impressively low capacitance, putting it neck and neck with the Lollar Tweeds. I like Lollar because he offers pickup sets that touch the boundaries with the Tweed set and the Special S, but considering this set goes for $285/$315, while the GFS Boston Blues go for $68 ( and look cool!), I don't think the Lollar set is a wise purchase in this case. Seeing as how these are otherwise basic AlNiCo 2 Strat pickups, there is nothing else noteworthy to report. Lollar Tweed 2013 Bridge DC Resistance: 5.88K Inductance: 2.363H Calculated C: 137pF (147-10) Gauss: ~750G, AlNiCo 2
Resonant Peak: dV: 12.8dB f: 8.55kHz Loaded (200k & 470pF): dV: 6.7dB f: 3.98kHz
Lollar Tweed 2013 Middle DC Resistance: 5.37K Inductance: 2.108H Calculated C: 118pF (128-10) Gauss: ~750G, AlNiCo 2
Resonant Peak: dV: 12.0dB f: 9.70kHz Loaded (200k & 470pF): dV: 6.5dB f: 4.31kHz
Lollar Tweed 2013 Neck DC Resistance: 5.29K Inductance: 1.855H Calculated C: 114pF (124-10) Gauss: ~750G, AlNiCo 2
Resonant Peak: dV: 11.7dB f: 10.5kHz Loaded (200k & 470pF): dV: 6.5dB f: 4.46kH Bode plot:Pic:
