Post by reTrEaD on May 11, 2018 14:31:58 GMT -5
In the event you would like to see a Design Module that isn't currently presented, you can make a request here. This thread isn't likely to see much activity but it's here if you need it. Of course full wiring diagram requests will continue to be made in individual threads on the Guitar Wiring board.
Post by reTrEaD on Aug 13, 2018 13:40:50 GMT -5
Apparently we are lacking a module for a standard Blower (solo) switch. I see a three-way version by Newey but not a simple two-way version. What's needed is a DPDT arrangement. - One pole will connect a pickup (usually the bridge) to its normal connection in the scheme or to the 'direct output' path.
- The other pole will connect the output jack to its normal connection in the scheme or to the 'direct output' path.
- An optional load resistor could be shown on the direct output path.
EDIT:It seems some things which appear inherently simple can lead to extended conversations. Had I known then what I know now, I would have made or directed others to make a discussion thread in Guitar Wiring leading to the construction of a Solo Switch module thread. Shifting gears... I'm moving all posts related to the discussion into one thread, starting with this post: guitarnuts2.proboards.com/post/86617/thread We'll hash out all the details, then create a Solo Switch module thread which will reside on the DM board.
