Post by ourclarioncall on Jan 27, 2020 19:07:59 GMT -5
Post by thetragichero on Jan 27, 2020 19:14:35 GMT -5
you won't be dissipating even 1/8 watt in a passive guitar so go for whatever is cheapest. 1/8 watt is tiny if space is a concern. 1/4 watt is fine. carbon film/metal film. whatever's cheapest
Post by ashcatlt on Jan 27, 2020 19:19:35 GMT -5
Since the price difference is so small, I’d go for metal film because the tolerance is tighter. Not that it makes enough difference to matter in guitar work, but you might want to use them for other things where it might. 2W is way more than you need, but it won’t hurt anything. They’ll just be a little bigger (physical dimensions) than absolutely necessary, but unless you’re populating a really tight pcb, they might again cover you in more situations.
Post by ourclarioncall on Jan 27, 2020 20:46:38 GMT -5
That’s for the help guys
I’m struggling to find a 0.68nf capacitor online
anyone got a link to where I can buy one in the uk ?
Post by frets on Jan 27, 2020 22:06:38 GMT -5
Post by JohnH on Jan 27, 2020 22:26:01 GMT -5
If you are after the 0.68nF from the recent volume switch module, you might find it more commonly referred to as 680pF Any type is fine. (note, it's not the same as 0.68uF)
1000pF = 1nF = 0.001uF (uF should be with Greek mu symbol, for microFarad)
Post by newey on Jan 28, 2020 23:15:13 GMT -5
Like this (lower case mu):
0.001μF (BBC code is, as ChrisK would say)
Post by ourclarioncall on Jan 31, 2020 10:41:13 GMT -5
Thanks folks
