Post by gn2staff on Mar 8, 2020 13:52:59 GMT -5
Foreword Phostenix' Guitar Wiring Diagram Library Modified TBX Tone Control 5-Way SHOop 5-Way SSOop Strat-O-Teles The Splender Strats Strat-X Strat-X2 Strat-X2 Plus Strat-X3 Teles 2 Pickup Teles 3 Pickup Teles Esquire Teles HH Guitars HSS Guitars HSH Guitars HHH Guitars Custom Wiring Setups Recent Additions Other Guitar Wiring Sites Comments Thread | HSS Guitars Here are some wiring options for 3 pickup guitars with a bridge humbucker and 2 single coil pickups. This page is still under construction. HSS With Series/Parallel Option 5-Way Switching: 1. Bridge – Tone 2 2. Middle & Bridge – Tone 2 3. Middle – Tone 2 4. Middle & Neck – Both Tones 5. Neck – Tone 1 Push-Pull Tone Down: Bridge Humbucker Push-Pull Tone Up: Bridge Coils in Parallel HSS With Dual Gang Volume Pot 5-Way Switching: 1. Bridge Humbucker – Tone 2 2. Middle & Bridge Split (Outside Coil) – Tone 1 3. Middle – Tone 1 4. Middle & Neck – Tone 1 5. Neck – Tone 1 HSS With Dual Gang Volume Pot 5-Way Switching: 1. Bridge Humbucker – Tone 2 2. Middle & Bridge Split (Inside Coil) – Tone 1 3. Middle – Tone 1 4. Middle & Neck – Tone 1 5. Neck – Tone 1 HSS With Dual Gang Volume Pot 5-Way Switching: 1. Bridge Humbucker – Tone 2 2. Middle & Bridge Split (Inside Coil) – No Tone 3. Middle – Tone 1 4. Middle & Neck – No Tone 5. Neck – Tone 1 HSS With Dual Gang Volume Pot 5-Way Switching: 1. Bridge Humbucker – Tone 2 2. Middle & Bridge Split (Outside Coil) – No Tone 3. Middle – Tone 1 4. Middle & Neck – No Tone 5. Neck – Tone 1 HSS With Dual Gang Volume Pot 5-Way Switching: 1. Bridge Humbucker – Tone 2. Middle & Bridge Split (Inside Coil) – No Tone 3. Middle – Tone 4. Middle & Neck – No Tone 5. Neck – Tone HSS With Dual Gang Volume Pot 5-Way Switching: 1. Bridge Humbucker 2. Middle & Bridge Split (Inside Coil) 3. Middle 4. Middle & Neck 5. Neck HSS With Dual Gang Push-Pull Volume Pot 5-Way Switching: 1. Bridge Humbucker – Tone 2 2. Middle & Bridge Split (Outside Coil) – Tone 1 3. Middle – Tone 1 4. Middle & Neck – Tone 1 5. Neck – Tone 1 Push-Pull Up: Position 1 Changes to Bridge Outside Coil – Tone 2 HSS With Dual Gang Push-Pull Volume Pot 5-Way Switching: 1. Bridge Humbucker – Tone 2 2. Middle & Bridge Split (Inside Coil) – Tone 1 3. Middle – Tone 1 4. Middle & Neck – Tone 1 5. Neck – Tone 1 Push-Pull Up: Position 1 Changes to Bridge Inside Coil – Tone 2 HSS With Dual Gang Push-Pull Volume Pot 5-Way Switching: 1. Bridge Humbucker – Tone 2 2. Middle & Bridge Split (Inside Coil) – Tone 1 3. Middle – Tone 1 4. Middle & Neck – Tone 1 5. Neck – Tone 1 Push-Pull Up: Position 1 Changes to Bridge Humbucker & Neck – Tone 2 HSS With Dual Gang Push-Pull Volume Pot 5-Way Switching: 1. Bridge Humbucker – Tone 2 2. Middle & Bridge Split (Inside Coil) – Tone 1 3. Middle – Tone 1 4. Middle & Neck – Tone 1 5. Neck – Tone 1 Push-Pull Up: Position 1 Changes to Bridge Humbucker & Neck – Tone 2 |
