Post by gn2staff on Mar 8, 2020 13:53:23 GMT -5
Foreword Phostenix' Guitar Wiring Diagram Library Modified TBX Tone Control 5-Way SHOop 5-Way SSOop Strat-O-Teles The Splender Strats Strat-X Strat-X2 Strat-X2 Plus Strat-X3 Teles 2 Pickup Teles 3 Pickup Teles Esquire Teles HH Guitars HSS Guitars HSH Guitars HHH Guitars Custom Wiring Setups Recent Additions Other Guitar Wiring Sites Comments Thread | HSH Guitars Here are some wiring options for guitars with 2 humbuckers and a single coil in the middle. This page is still under construction. HSH with Autosplit in Positions 2 & 4 This wiring setup gives you the Bridge pickup as a humbucker in Position 1, but as a single coil in Position 2. Similarly, the Neck pickup is a humbucker in Position 5, but a single coil in Position 4. Position 3 is the Middle pickup by itself. A push-pull (or push-push) tone pot gives the option of always having the Neck & Bridge pickups as single coils. 5-Way Switching: Push-Pull Down: 1. Bridge Humbucker 2. Middle & Bridge Inside Coil 3. Middle 4. Middle & Neck Inside Coil 5. Neck Humbucker Push-Pull Up: 1. Bridge Inside Coil 2. Middle & Bridge Inside Coil 3. Middle 4. Middle & Neck Inside Coil 5. Neck Inside Coil The same wiring setup as shown above, but with DiMarzio pickup wire colors. HSH with Autosplit in Positions 2 & 4 The same idea as above, but this setup gives you the outside coil of the Neck pickup & the inside coil of the Bridge coil. HSH with S-1 for Strat or Fat Strat Type Switching 5-Way Switching: S-1 Up: 1. Bridge Inside Coil 2. Middle & Bridge Inside Coil 3. Middle 4. Middle & Neck Outside Coil 5. Neck Ouside Coil S-1 Down: 1. Bridge Humbucker 2. Bridge Humbucker & Middle 3. Neck & Bridge Humbuckers 4. Neck Humbucker & Middle 5. Neck Humbucker The same wiring setup as shown above, but with DiMarzio pickup wire colors. HSH with S-1 for Strat or Modern PRS Switching 5-Way Switching: S-1 Up: 1. Bridge Inside Coil 2. Middle & Bridge Inside Coil 3. Middle 4. Middle & Neck Outside Coil 5. Neck Ouside Coil S-1 Down: 1. Bridge Humbucker 2. Bridge Humbucker & Neck Outside Coil 3. Neck & Bridge Humbuckers 4. Neck Outside Coil & Bridge Inside Coil 5. Neck Humbucker The same wiring setup as shown above, but with DiMarzio pickup wire colors. HSH with S-1 for Strat or Modified Modern PRS Switching 5-Way Switching: S-1 Up: 1. Bridge Inside Coil 2. Middle & Bridge Inside Coil 3. Middle 4. Middle & Neck Outside Coil 5. Neck Ouside Coil S-1 Down: 1. Bridge Humbucker 2. Bridge Humbucker & Neck Outside Coil 3. Neck & Bridge Humbuckers 4. Neck Humbucker & Bridge Inside Coil 5. Neck Humbucker The same wiring setup as shown above, but with DiMarzio pickup wire colors. HSH with S-1 for Strat or Modern PRS Switching and Modified TBX 5-Way Switching: S-1 Up: 1. Bridge Inside Coil 2. Middle & Bridge Inside Coil 3. Middle 4. Middle & Neck Outside Coil 5. Neck Ouside Coil S-1 Down: 1. Bridge Humbucker 2. Bridge Humbucker & Neck Outside Coil 3. Neck & Bridge Humbuckers 4. Neck Outside Coil & Bridge Inside Coil 5. Neck Humbucker |
