D Pots
May 1, 2020 0:07:47 GMT -5
via mobile
Post by frets on May 1, 2020 0:07:47 GMT -5
Hey Guys, Hope you’re all being safe and your families are safe.
So I buy these Bourns Pots, 16 of them, thinking they were A logs given the pot number ended in a 254A2. But oh no, they arrive and they’re D pots. D250’s. I figure they are for digital applications but I’m hoping one in the fellowship can explain these to me. They look like a regular ol pot. Thanks.
D Pots
May 1, 2020 0:41:34 GMT -5
via mobile
Post by thetragichero on May 1, 2020 0:41:34 GMT -5
oooh you got good'ns from my understanding D taper is a closet approximation of logarithmic taper than A, as all pots are made up of linear segments approximating a logarithmic curve (i hear my high school calculus teacher's voice calling them "piecewise linear") so no need to 'fret'
D Pots
May 1, 2020 0:45:04 GMT -5
via mobile
Post by thetragichero on May 1, 2020 0:45:04 GMT -5
stolen from a diysb post that came up from a 'bingle' search
D Pots
May 1, 2020 6:20:00 GMT -5
via mobile
Post by JohnH on May 1, 2020 6:20:00 GMT -5
Hi frets How about checking it out with a meter? If you set it to mid turn as carefully as possible, then you could measure resistance from middle lug to each outer lug to see if you get a ratio of 10% to 90%
D Pots
May 1, 2020 12:11:18 GMT -5
via mobile
Post by frets on May 1, 2020 12:11:18 GMT -5
Hi Trag and John, Thanks for your help. I will hook them up to a meter and check their resistance across the sweep. I am glad to know they are of extreme tolerance. I just can’t believe in all my years of guitar making and fixing that I’ve never encountered such.
D Pots
May 1, 2020 16:20:57 GMT -5
via mobile
Post by thetragichero on May 1, 2020 16:20:57 GMT -5
if these are pots I'm thinking of they also give some "resistance" as you turn em, of which i am a huge fan. i was a bit of a wild man in my younger years so pots that wouldn't change their settings by simply looking at them the wrong way was a must although I've also primarily between the type of neanderthal who just puts everything on 10 and leaves it there
D Pots
May 1, 2020 18:12:05 GMT -5
via mobile
Post by thetragichero on May 1, 2020 18:12:05 GMT -5
pulled this outta something. gonna be the volume pot for my current single p90 build
D Pots
May 2, 2020 8:37:29 GMT -5
via mobile
Post by frets on May 2, 2020 8:37:29 GMT -5
Trag, That’s exactly what they look like with the D250k written above the lugs. BTW - that’s quite the beauty shot of the pot. It looks like you’re standing on a mountain precipice looking down over a granite outcropping. Ha!
D Pots
May 4, 2020 10:05:36 GMT -5
Post by frets on May 4, 2020 10:05:36 GMT -5
Update to D Pots: I took John’s and Trag’s suggestions and did a test of two Bourns Pots - a Bourns A250k vs a Bourns D250k, with regard to overall taper sensitivity. I went through a random selection of my A pots and then tested the 16 D pots that I ordered in error, to find two of each that matched in terms of similar “k’s”- with the A250k measuring in at A248k and the Type D at D249k. I measured at increments that I “felt” represented an incremental turn of the pot; i.e., position 1,2,3...so on). I did five trials of the incremental pot turns, computed the average of each pot; and, created the following chart. As one can garner, the Type D Pot exhibited a higher degree of incremental sensitivity than its cohort variable (Type A Pot). However, one may ask, “is this difference significant?” Statistically, the answer is “No.” The two variables exhibit variances that are not significantly different. I put the data into my Stat Program and did a simple Analysis of Variance Test between the two regarding incremental differences (ANOVA). It resulted in 7 of 8 tests of the taper differences between Type A and Type D pots that were not significantly different. I then found a similar graph to mine on the web conducted by a Dude overseas that resulted in a similar graphic trend between Type A and Type D pots. Whew, so there is a difference as you can see; however, the difference is not statistically different. Boo Hoo! Now do I think you’ll hear the differences between Type A and Type D pots. Probably not. Ha !
D Pots
May 4, 2020 15:19:05 GMT -5
Post by JohnH on May 4, 2020 15:19:05 GMT -5
Thanks frets that's great. I have learnt something today and its still only 6am! I had not appreciated the difference A to D before.
One thing that occurs to me is that if you are adding treble bleed circuits, which tend to 'flatten the curve', or make the taper less steep, a D pot would be a good thing to start with.
D Pots
May 4, 2020 23:00:13 GMT -5
via mobile
Post by frets on May 4, 2020 23:00:13 GMT -5
Thanks John, I appreciate your recommendation to pursue it. I’m interested in the treble bleed aspect you referred to. Basically the same measurement comparison as the one I did using treble bled A and D pots? Just making sure.
