albert
Post by albert on May 28, 2020 20:00:46 GMT -5
Hello....I'm mainly here to check some of your forum set up tips even though I've had a ProBoard before. I'm setting up another one for art work. Can you give me a link to a good proboard art forum please? I used to be a guitarist but turned flute player and then artist. Thanks !!
Post by newey on May 29, 2020 10:42:58 GMT -5
Hello and Welcome!Guitarist and artist likely upped your dating status. Flautist, probably not so much . . . I'm not familiar with any ProBoards art forums, so can't give you any recommendations there. As for the way this forum is set up, most of the bits and pieces are available through the ProBoards support forum. Any of the custom coding here has been done by two of our members, so if there is some specific feature that Proboards doesn't have available as a plug-in, ask and maybe one of them can give some advice.
Post by thetragichero on May 29, 2020 11:23:03 GMT -5
i was gonna post that i could never figure out how to hook a flute up to a fuzz pedal but figured it wasn't very helpful
Post by reTrEaD on May 29, 2020 12:01:50 GMT -5
Any of the custom coding here has been done by two of our members The best stuff was coded by Yogi B although I have done a few small pieces. Also, JohnH did the lion's share of the work translating the html of the Phostenix Files to BBCode. albert, if you want to see the scripts and html in the headers and footers, you can 'View Page Source' in your browser. This will also show which plugins are in use.
albert
Post by albert on May 29, 2020 19:45:10 GMT -5
Thanks..reTreAd .....I'll make sure I ...Don't waste good ....from here.
albert
Post by albert on May 29, 2020 19:52:05 GMT -5
i was gonna post that i could never figure out how to hook a flute up to a fuzz pedal but figured it wasn't very helpful That fuzz pedal sounds great.
albert
Post by albert on May 29, 2020 20:00:48 GMT -5
Hello and Welcome!Guitarist and artist likely upped your dating status. Flautist, probably not so much . . . I'm not familiar with any ProBoards art forums, so can't give you any recommendations there. As for the way this forum is set up, most of the bits and pieces are available through the ProBoards support forum. Any of the custom coding here has been done by two of our members, so if there is some specific feature that Proboards doesn't have available as a plug-in, ask and maybe one of them can give some advice. Will do and thanks !!
albert
Post by albert on May 30, 2020 1:36:08 GMT -5
Just thought I would show you this when I used to play guitar and ukulele...etc. The art work is called Serendipity and they are of two ukuleles in Picasso style to cheer up our kitchen...done about 28 years ago . Everyone thinks they are guitars.. and I gave away 2 more and one was of a guitar with sheet music as a background...which was a stunner.
Post by newey on May 31, 2020 11:13:53 GMT -5
I like the piece. What's the medium? Is it a collage plus paint?
