Post by antigua on Jun 28, 2020 23:42:32 GMT -5
A few years ago I bought some AlNiCo pole pieces from Addiction FX and recorded values of them with an LCR meter and bode plotter. A post about it is on the next somewhere, but I couldn't find it, so I just performed the tests again, this time a little better. Also, this time I've used Ken Willmott's integrator.
One of the plots is of "degaussed A5", these are pole pieces that have about 3% of their full strength charge. They would be unusable as is. That and "air core" are included FYI, neither is usable as is.
Zoomed out:
Zoomed in:
Air coil:
Flux density: _ _ 0 Gauss
Inductance: _ _ _ 1.480 H @100hz
Q: _ _ _ _ _ _ _ _1.688 @1khz
Resonant Peak: _ _9.03 kHz
Peak Amplitude: _ 21.3 dBV
Test Voltage: _ _ 5.2 Vpp
AlNiCo 2
Flux density: _ _ ~700 Gauss
Inductance: _ _ _ 2.193 H @100hz
Q: _ _ _ _ _ _ _ _2.40 @1khz
Resonant Peak: _ _7.46 kHz
Peak Amplitude: _ 14.4 dBV
Test Voltage: _ _ 4.0 Vpp
AlNiCo 3
Flux density: _ _ ~550 Gauss
Inductance: _ _ _ 2.214 H @100hz
Q: _ _ _ _ _ _ _ _2.37 @1khz
Resonant Peak: _ _7.49 kHz
Peak Amplitude: _ 13.3 dVB
Test Voltage: _ _ 3.8 _Vpp
AlNiCo 4
Flux density: _ _ ~750 Gauss
Inductance: _ _ _ 2.180 H @100hz
Q: _ _ _ _ _ _ _ _2.38 _@1kHz
Peak Amplitude: _ 14.3 dBV
Test Voltage: _ _ 3.7 Vpp
AlNiCo 5
Flux density: _ _ 1000 Gauss
Inductance: _ _ _ 2.016H H @100hz
Q: _ _ _ _ _ _ _ _2.23 @1khz
Resonant Peak: _ _7.80 kHz
Peak Amplitude: _ 15.9 dBV
Test Voltage: _ _ 4.05 Vpp
Degaussed AlNiCo 5
Flux density: _ _ ~30 Gauss
Inductance: _ _ _ 1.874 H @100hz
Q: _ _ _ _ _ _ _ _2.07 @1khz
Resonant Peak: _ _8.07 kHz
Peak Amplitude: _ 16.9 dBV
Test Voltage: _ _ 4.2 Vpp
The output voltage varied by pole piece set, but I wanted them normalized in order to compare apples to apples, so I recorded the "test voltage", which indicates how much drive voltage was required in the exciter coil in order to get them all to be even. A lower test voltage indicates that there was a stronger coupling coefficient, and vice versa.
The main take away from this testing is that AlNiCo 2, 3 and 4 are virtually the same, with just slight differences between them, while AlNiCo 5 stands farther apart. Another take away is that the degaussed AlNiCo 5 varied significantly from the charged up AlNiCo 5, demonstrating how the magnetized state of the AlNiCo alters the inductance and the Q factor of the coil.
A member on another forum claims that these AlNiCo 4 sample might be bogus, and that AlNiCo 4 should more closely resemble AlNiCo 5. Unfortunately, there is not much data available about AlNiCo 4 relative to the other commonly used grades, so I don't have enough information on hand to confirm or deny that this is the case. In this case, the electrical values are very nearly identical to AlNiCo 2, but the residual flux density (Br) was noticeably higher.
Zoomed out:
Zoomed in:
Air coil:
AlNiCo 2
AlNiCo 3
AlNiCo 4
AlNiCo 5
Degaussed AlNiCo 5
