Post by frets on Jul 26, 2020 20:20:57 GMT -5
Hi Guys, I’m working on a new harness that I want to put in an old ‘84 Strat I picked up. I’ve made John’s Other Strat Lover’s Harness and have it in a ‘98 Strat. But for this one, I want the Blender to only have two functions - on one side, blend in the neck, on the other side, blend in the bridge. So this harness has Push-Pull Volume/Series, Push-Pull Tone/Phase and the Blender for N and B. I want B+N, B+M+N. So, I don’t need any diagram, I just can’t figure out how to wire this standard pot. Give me a regular blend pot and I’m fine; but, I still struggle with a standard blender. It’s probably two simple connections. Any quick direction would be helpful.
Post by JohnH on Jul 26, 2020 20:39:04 GMT -5
Sounds like a case where you take a standard log pot, use one centre lug and the middle lug (same two pot lugs as a tone pot), and wire one direct to the neck hot wire and one to the bridge hot.
When either B or N are selected on the 5-way, the blender will mix in the other, arriving gradually at B+N or B+M+N
A no-load pot (bought or converted) is even better.
Post by frets on Jul 26, 2020 23:04:29 GMT -5
Thanks John, I knew it was something simple.
