Post by sumgai on Aug 8, 2020 15:07:04 GMT -5
frets, OK, so now we have an output, and I previously mis-identified the two pots... sorry 'bout that. The enlarged switching details are good enough for me to read, thanks. But after tracing through it all, I can't reconcile your Truth Table with what I see for connections. It might help if you were to label the terminal closest to the common for each pole as either Pos 1 or Pos 5. Perhaps that'll clear up my confusion.... (Don't forget to label the Truth Table as well, sometimes it's not appropriate to assume that the top-most table entry is indeed Pos 1.) And what about those two components hanging off of the DPDT attached to the Vol pot, they still have no connections to the rest of the circuitry. Keep going lady, you're about to break through! HTH sumgai
Post by frets on Aug 8, 2020 16:43:58 GMT -5
Hey Sumgai, You know, I have all these schemes in my head and when I sit down to draw them out, I always encounter this. I’m sorry. I can tell you I’ve built this harness like 50x so it does work. What I need to do is use the new Visio program I have. I think I’ll have more control over details - like the switch. I still don’t see the two wires not reconciled from the volume. Ha! It will be an AHA moment .....soon.....I hope.😻
Post by JohnH on Aug 8, 2020 17:55:25 GMT -5
Hey frets, If you have Visio, you might like to check out the 'Guitar Stencils Project' sites.google.com/site/guitarstencilsproject/I don't have those myself, but if you can get them, then you could draw guitar circuits like Phostenix.
Post by frets on Aug 8, 2020 18:01:21 GMT -5
John, Thanks, that was what I am exactly going to do. I think it will be clearer than DIYC. And I see my mistake AHA!! I’ll fix it.
